EMP attack
Posted: Fri Sep 09, 2016 11:47 pm
by Brickren
I have a question as to the survivability of a Pinz in an EMP attack. In the original configuration shielded cables and points, would Our truck still run? I imagine alternator would be toast as well as all bulbs, but would she still run? What additional steps and precautions would one have to make to make her survive? I already have my foil hat, so this is a question I would like help with. BTW, I am looking for a points setup if someone wants to part with one. Thanks, Brian
Re: EMP attack
Posted: Sat Sep 10, 2016 9:37 pm
by VinceAtReal4x4s
I've been in these conversations a few times and as far as I understand it, most of the Pinz would be fine. The areas of concern in that theoretical scenario are more micro-electronic related, like aftermarket ignitions and injection circuitry, if you had it. Light bulbs aren't affected and most of the alternator would be fine... maybe the regulator could (unlikely) suffer. ?
The stock ignition/wires/plugs wouldn't be affected regardless; the shielding is for radio interference issues and I don't think the points would be affected.
Re: EMP attack
Posted: Sat Sep 10, 2016 10:47 pm
It also would depend on just how close the Pinz was to the EMP - given a strong enough (being close enough) pulse, even a Pinz would be toast. But the energy of the pulse falls of by the square of the distance so twice as far gives only 1/4th the energy; ten times as far is 1/100th the energy, etc. I would guess that many modern cars would survive in the outskirts of a blast; a stock Pinz might survive anything beyond ground zero. Shielded cables for the plugs do not have much value; the "loops" of wire that they create is what the EMP preys upon, but the pulse would just create a spark at the plug. Same with bulbs - the energy would just go into trying to get them to light up, but the EMP is so fast that they would never have time to glow. As Vince said, the tiny electronics may not have a place for the energy to go and that is what will cause the failure.
