solinoid adjustment
solinoid adjustment
Bought a new starter solinoid and manual states that the clevis must be adjusted to 34+- Milimeters but cant seem to get to that adjustment. Is this adjustment with the solinoid retracted into the coil or is it when the solinoid is at its resting position without voltage applied? any help will be appreciated
710M
710M
geez Jim...that was rough...actually the original solinoid in the truck was replaced with a new one...using the adjust to the one that came out specs...which gave me the same results as the original...which is...periodic no start condition without repeated starter button engagement...and no its not the puch button switch that has been replaced with new. I went back to basics and checked the manual which stated a 34 +- 1 MM but when I tried to adjust to this spec it seemed as though it cannot be done however if the solinoid is in the retracted position it may be possible to achieve that spec...and this is what I am asking
710M
710M
The illustration in the manual shows plunger retracted.
Not trying to be harsh , just to the point
You may wish to also check the starter brushes(click no spin), and ground circuits. I have also found unplugging and replugging in the harness connectors under the dash sometimes solve intermittent issues. Especially the harness with the fat red wires to the ignition and light switches(main power).
- Jimm391730
No the starter bendix is fine and engages properly, the starter was disassembled and armature checked, brushes and brush holders checked, bendix checked ,bushings checked. My guess is that the previous owner may have fooled with the solinoid adjustment which I will verify tomorrow. If after the solinoid is verified for proper adjustment and the problem is not resolved, then I will check underdash wiring connectors, and possibly perform voltage drop tests.
710M
710M
