I was looking to replace the original battery relay on my rig. Would any 24v high amp 4 prong relay work. I know they have OEM replacements but they are like $86. I found a 24v 40 amp relay for $4. Am I missing anything here? Thanks for any help.
Smiley
Battery Relay Replacement?
I'll stick my neck on the line and say yes, it will work. It's only a relay. The originals have a mounting bracket built in, which you'll have to get round but as long as it's well sealed you should be fine. You could even relocate it somewhere more accessible, I suppose!
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Robin
Pinzgauer 710K
MegaJolt ignition
Need to change my relay too as it happens. According to http://www.sdp-pinzgauer.org/html/bypass_relay.html it's only a 20A one so yours will be more than adequate. In fact, I'm wondering whether with headlights on, Eberspächer running etc. the original one is powerful enough?
Robin
Pinzgauer 710K
MegaJolt ignition
Robin
Pinzgauer 710K
MegaJolt ignition
