turn signal switch
turn signal switch
Ok. I replaced the 4way flasher and flasher relay and now have working 4way lights. I have power to the high/low beam switch and it works but I have no power to the turn signals. I don't have a wiring diagram to find out which is the power supply. then i can follow it to the source and find out why I have no power.
Re: turn signal switch
Andre, power comes from the ignition switch and supplies power side of #12 breaker.
You can download wiring diagrams from the SDP site
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Robin
Pinzgauer 710K
MegaJolt ignition
