Turn signal woes
Posted: Sun Jun 16, 2013 4:14 pm
Hi,
My name is Arie and I'm new to this forum and Pinz ownership. My 712M is giving me grief with electrical problems in that I now don't have turn signals, brake lights or headlight hi-beams. When my turn signals went south, I had the steering at full lock and I saw a little arc flash down to left of the steering column. The #12 circuit breaker popped but it does reset with power applied. My 712M has been retrofitted with the EG23 flasher ... it's fine since my hazard lights work properly. Other possible related things to note:
- The previous owner also installed an aftermarket brakelight micro switch (I understand the OEM brakelight switches are problematic).
- I took apart the turn signal switch; dusty inside but no sign of shorts. Also notice black electricians tape wrapped around the steering shaft?? and that the screws holding the switch/stalk to the housing are stripped.
Any thoughts? I know I need a complete new turn signal switch assembly but do my problems run deeper than this? I wouldn't think a worn-out turn signal switch would lead to no brake lights.
I bought my 712M from a previous member here .. Eric Minnick. Eric, if you still visit this forum, please chime in.
Also, Jim LaGuardia helped immensely with my purchasing the 712M from Eric. Jim, if your encyclopedic knowledge of Pinzes in general and using your wizardry to help Eric with fixes and patches over years can shed some light on this, I'd be very grateful.
