circuit breakers
Posted: Thu Jul 23, 2015 2:24 pm
by blackstack
on hot days my breakers pop....short of installing AC in the cab ...is there a trick to keep it cooler under there?
Re: circuit breakers
Posted: Thu Jul 23, 2015 6:49 pm
by 4x4Pinz
change them out to aviation/marine type. not very expensive and they will be more reliable.
Posted: Fri Jul 24, 2015 9:40 am
by rmel
Which breaker(s) is/are poping? You may want to make sure you don't
have some other problem only to find a breaker upgrade has the same
problem :? Being at Whidbey Is. is not exactly all that hot -- relatively
skeak'n.
ron
Posted: Fri Jul 24, 2015 12:22 pm
by blackstack
4x4Pinz wrote:change them out to aviation/marine type. not very expensive and they will be more reliable.
Hello...do you have a stock number or a source...did you have to do any modifications or do they fit in the fuse block?
Posted: Fri Jul 24, 2015 6:20 pm
by 4x4Pinz
I used some Seachoice breakers
http://www.seachoice.com/wp-content/the ... .html#p=17
needed to convert wires from ring ends to female spade ends and but the breakers fit in the holes that were in the dash. The rubber mounting and metal shroud that contain the original breakers were no longer needed.
Been a several years now and have experienced no troubles with the new style breaker.
Posted: Sun Jul 26, 2015 6:12 pm
by blackstack
Thanks for the helpfull reply !!
