Brake pressure switch sticking on
My brake lights sometimes stay on when the brake pedal is released. Is there an after market switch that would do the job or does it have to be a genuine part? Would it be possible to fit without the need to bleed the brakes?
It is a Mercedes part and VW part. You must use the short un-tapered thread version with copper sealing washer.
Using the tapered thread type will damage master cylinder and leak
Switch can be installed without bleeding if done quickly. After installing new switch, pump brake pedal 30 times to expell any air from master back to reservior and check for leaks.
Sorry to bring up a older topic but does anyone have the part number or a vehicle that this switch came off of?
The only thing I could find was this;
http://cgi.ebay.com/ebaymotors/Beck-Arn ... 35a9e7a885
Switch
The switch is available from SAV: http://www.pinzgauer.com/showdetails.ph ... 101366062/
Maybe someone else on the forum has the VW part number.
Paul
Paul
Brake Light Switch
I haven't replaced one yet but I found this info in the Pinzgauer Alternative Parts List.
"Brake Light Switch Volkswagen or NAPA 1981 Rabbit
(CAUTION! THERE ARE 2 TYPES, ONLY ONE FITS!!)":shock:
NAPA sells a large assortment of copper seal washers also.
TIP: If you want to re-use the old washer you should
anneal it first, so that it will make a good fit.
The eBay link above lists what looks to be the same part.
Read what Jim Laguardia says about the threads!
Edit; July 5, 2010, PDT
Thomas E.
Sonora, CA
712 Camper
[img][url]M:\avatar\DSCN0010%20(Custom).JPG[/url][/img]
Sonora, CA
712 Camper
Did you get the switch from a 1981 VW Rabbit? There is no way the threads could be different.Scooter wrote:I tried the VW switch way with the local VW shop. Found out it was the wrong thread type after I bought it and tried to install it. What a mess. You are better of getting the SAV part from the start and saving a lot of head aches.
Scooter
They looked up the part number and said there was 2 part numbers. they only had one in stock, of course it was the wrong one. I did not take out the old one until I had the new one, so there was no way to konw. I showed them the picture, but it was hard to tell if the treads were tappered or not.
Scooter
Scooter
