Sacrilege? Lowered ride height?
Pondering a 710K, but it appears it won't fit through 80" garage door opening. Don't want the Pinz to have to sit out during rainy season.
Have thought about different set of wheels/tires for storage - too much work.
Have considered taking off wheels and bolting on heavy duty low profile frames - same issue, too much work.
Has anyone used air springs to be able to adjust ride height on a Pinz? Or is this impossible?
Due to oversize tires currently mounted, I would need to lose about 6" of height to clear the 80" opening.
- eToothpaste
There is a guy on these forums that fitted his 710 with air springs. You should find it in a search.
He is no longer active here, as I have tried a few times to contact him with no response. He lived in southwest Utah.
How about a bigger garage?
Matt
Re: Sacrilege? Lowered ride height?
If you have an older garage entrance, you may have standard 2x2x16" headers with several 2x4's above and below. It all adds up.
This can all be replaced with a "Gluelam" which can be considerably less in thickness and stronger. Then get yourself a door with
more sections, I've found one that is only 4" below the ceiling. This gets you at least 8" more clearance. I have the same problem
and looked into this -- it's on my wish list for to be done's. Don't putz with the suspension or tires you won't like that.
P.S. Don't ask the town building planners They sting you on these changes $$$$$ and time -- didn't hear that from me
ron
ron
You shouldn't need a permit to "repair" a garage door.
George Cameron
Yarnell, AZ
1979 Pinz 710M
Molon Labe
Yarnell, AZ
1979 Pinz 710M
Molon Labe
From my experience, that depends on the municipality. In Madison, WI, we once got popped for no building permit for replacing a toilet! Not putting in new rough plumbing, just bolting down a new crapper.GRCameron wrote:You shouldn't need a permit to "repair" a garage door.
Here, replacing a door is much different than repairing a door. Still, I'd probably ask forgiveness instead of permission, and just do it, maybe on a weekend...
Thanks, guys. I am no stranger to renovations, but in this case I think the vehicle would need to give way. The garage is full on brick and masonry construction (Not just facade) and has a good 25yrs of seniority on any Pinz.
Anything I am missing as far as downsides of the air suspension, other than cost and the need to carry onboard air tank and a compressor?
Lower the garage floor somehow?
or...
Wow! Here in Arizona things are a little different - more freedom. That's why my wife and I moved here from Kalifornia.undysworld wrote:From my experience, that depends on the municipality. In Madison, WI, we once got popped for no building permit for replacing a toilet! Not putting in new rough plumbing, just bolting down a new crapper.GRCameron wrote:You shouldn't need a permit to "repair" a garage door.
George Cameron
Yarnell, AZ
1979 Pinz 710M
Molon Labe
Yarnell, AZ
1979 Pinz 710M
Molon Labe
cant you just deflate the tires when entering the garage????
710M
710M
x2Pinzgauer Pete wrote:cant you just deflate the tires when entering the garage????
Where is the like button
Edzz, what is going on there? Rubber donuts on the brake drums??edzz wrote:or...
Yeah, that was my first thought. Asked the current owner when I saw the car - said he had already tried that, at least down to 10psi. Showed me the scar on his garage opening. Assuming any lower there is a good risk of popping a bead out?TechMOGogy wrote:x2Pinzgauer Pete wrote:cant you just deflate the tires when entering the garage????
It is my understanding that they are waiting to drive on-board a train that has height limits. The "wheels"E_Swift wrote:Edzz, what is going on there? Rubber donuts on the brake drums??edzz wrote:or...
are just big enough to protect the brakes.
