Bleeding brakes not giving me any results
Posted: Sat Dec 17, 2011 8:44 pm
by cruzoropeza
I keep bleeding brakes but I still have to double pump in order to get good stoping power what should I be checking? Thanks in advanced!
Re: Bleeding brakes not giving me any results
Posted: Sat Dec 17, 2011 11:08 pm
Recommend adjusting the shoes, really not a difficult thing. Took me awhile the first time but once I found out that the two threaded holes are for bolts
that remove the drums it was a cinch. I am sure that others will chime in if you have questions. Also a great time to clean everything out...wear a dust mask
that dust is not good for you.
I had your same issue...that's how I know.
Posted: Sat Dec 17, 2011 11:16 pm
by cruzoropeza
I'll try that out thanks!
Posted: Sun Dec 18, 2011 12:32 am
by VinceAtReal4x4s
Air will just give you a spongy feeling. Like krick3tt said, adjusting shoes will likely solve having to double pump but you might need new shoes if you lost too much material, or in a more extreme case, new drums if that doesn't work and they look worn or have been turned down once already.
Posted: Sun Dec 18, 2011 10:31 am
by cruzoropeza
Hopefuly it's just an adjustment I'll check it oit when I return home next week!
Posted: Sun Dec 18, 2011 12:13 pm
by spandit
I had exactly this and it was the shoes that just needed adjusting. Give them a good clean whilst you've got the drums off
Posted: Sun Dec 18, 2011 12:53 pm
Posted: Sun Dec 18, 2011 4:05 pm
by cruzoropeza
Thanks for the link!
Posted: Sun Dec 18, 2011 9:39 pm
by totaljoint
I was amazed at how much sand/grit accumulated in my brake cylinders when I took them apart. Driver side front was
completely clogged up.
Big difference in the braking ability and firmness of pedal when I cleaned and flushed them.
Ed
Posted: Mon Dec 19, 2011 5:00 am
by spandit
I generally power-hose mine when I take the drums off after off-roading - the pile of crud that drains out is quite something. I also give the pads a scrub with a wire brush and then spray with brake cleaner to get any grease off
Posted: Sat Jan 07, 2012 12:38 am
by cruzoropeza
I finally got around to adjusting the brakes and it worked!!!! Thank you all for your tips its like day and night!!!!
