I'm wondering if these uniquely tall tires will fit a Pinz. My 710K sits pretty tall at 82 inches at the roofline, so no sagging springs, but what about turning/bump clearance? Here are the specs.
Technical Information from michelin site for new 255/100R16 XZL tyres:
Michelin reference 110650
Ply rating
Unique point 134/128 J
Nominal load per axle - single fitment (kg) 3400
Nominal load per axle - twinned fitment (kg) 6400
Nominal pressure in bars (single fitment) 4.50
Nominal pressure in bars (twinned fitment) 4.50
Nominal pressure in bars (unique point) 5.75
Wheel recommended 6.50H
ETRTO section (mm) 260
ETRTO diameter (mm) 936
Free section (mm) 255
Free diameter (mm) 923
Crushed section (mm) 286
Crushed radius (mm) 426
Rolling circumference (mm) 2798
Minimum distance between axle centres (mm) 288
Tread depth (mm) 16.5
Regrooving depth (mm)
Weight in kg 39.90
Tube
Flap
Sealing ring
Regulation 54 007700
ETRTO approved rims 6.50H
Will These Tires Fit?
'76 710K
- David Dunn
Re: Will These Tires Fit?
255/100-16 XZL are just a modernized name for the 9.00-16
I my opinion, you are getting way too tall and heavy for the little Pinz engine to push ( especially a 30+ year old worn engine).
The Brit specs for their Pinzes was the 8.25-16 XZL ( Also the US 718's)
255/85-16 (33") is about as tall as you want
The last tires fitted standard to the 716 and 718 were 285/75-16 which are 33" also... but remember those truck have a whole lot more HP to move them, power steering and 4 and 6 wheel disc brakes to slow the momentum
Thanks David, those were the size I was originally considering when I came across the Michelin's. The 255-85/16 does seem like a reasonable compromise. I think that's the direction I'll go. Looking at the Toyo Open but they're not cheap or easy to find.
'76 710K
If you can get those XZL in 255/100R16 radials get them fast!!!!. They will fit perfectly and you will gain a lot top highway speed without too much compromise off-roading, just prepare to have stronger arms if you drive the pinz often... I have had 900-R16 all the time but with tubes and those are a pita because of the tubes... now with 750R16 radials until I can get those michs.... They are used here in a vehicle "built" by the goverment called TIUNA but havent found any wrecked yet...
ALEX.
'89 EX-VENEZUELAN ARMY 712M
