Sacrilege? Lowered ride height?
Posted: Wed Sep 24, 2014 10:59 pm
by E_Swift
Pondering a 710K, but it appears it won't fit through 80" garage door opening. Don't want the Pinz to have to sit out during rainy season.
Have thought about different set of wheels/tires for storage - too much work.
Have considered taking off wheels and bolting on heavy duty low profile frames - same issue, too much work.
Has anyone used air springs to be able to adjust ride height on a Pinz? Or is this impossible?
Due to oversize tires currently mounted, I would need to lose about 6" of height to clear the 80" opening.
Posted: Wed Sep 24, 2014 11:42 pm
by eToothpaste
There is a guy on these forums that fitted his 710 with air springs. You should find it in a search.
He is no longer active here, as I have tried a few times to contact him with no response. He lived in southwest Utah.
How about a bigger garage?
Re: Sacrilege? Lowered ride height?
Posted: Thu Sep 25, 2014 12:04 am
by E_Swift
Posted: Thu Sep 25, 2014 12:15 am
by rmel
If you have an older garage entrance, you may have standard 2x2x16" headers with several 2x4's above and below. It all adds up.
This can all be replaced with a "Gluelam" which can be considerably less in thickness and stronger. Then get yourself a door with
more sections, I've found one that is only 4" below the ceiling. This gets you at least 8" more clearance. I have the same problem
and looked into this -- it's on my wish list for to be done's. Don't putz with the suspension or tires you won't like that.
P.S. Don't ask the town building planners
They sting you on these changes $$$$$ and time -- didn't hear that from me
ron
Posted: Thu Sep 25, 2014 12:41 am
by GRCameron
You shouldn't need a permit to "repair" a garage door.
Posted: Thu Sep 25, 2014 7:21 am
GRCameron wrote:You shouldn't need a permit to "repair" a garage door.
From my experience, that depends on the municipality. In Madison, WI, we once got popped for no building permit for replacing a toilet! Not putting in new rough plumbing, just bolting down a new crapper.
Here,
replacing a door is much different than
repairing a door. Still, I'd probably ask forgiveness instead of permission, and just do it, maybe on a weekend...
Posted: Thu Sep 25, 2014 8:34 am
by E_Swift
Thanks, guys. I am no stranger to renovations, but in this case I think the vehicle would need to give way. The garage is full on brick and masonry construction (Not just facade) and has a good 25yrs of seniority on any Pinz.
Anything I am missing as far as downsides of the air suspension, other than cost and the need to carry onboard air tank and a compressor?
Posted: Thu Sep 25, 2014 9:33 am
by pinzinator
Lower the garage floor somehow?
Posted: Thu Sep 25, 2014 9:39 am
or...
Posted: Thu Sep 25, 2014 10:12 am
by GRCameron
undysworld wrote:GRCameron wrote:You shouldn't need a permit to "repair" a garage door.
Here,
Wow! Here in Arizona things are a little different - more freedom. That's why my wife and I moved here from Kalifornia.
Posted: Thu Sep 25, 2014 11:08 am
by Pinzgauer Pete
cant you just deflate the tires when entering the garage????
Posted: Thu Sep 25, 2014 12:19 pm
Pinzgauer Pete wrote:cant you just deflate the tires when entering the garage????
x2
Where is the like button
Posted: Thu Sep 25, 2014 9:30 pm
by E_Swift
edzz wrote:or...
Edzz, what is going on there? Rubber donuts on the brake drums??
Posted: Thu Sep 25, 2014 9:32 pm
by E_Swift
TechMOGogy wrote:Pinzgauer Pete wrote:cant you just deflate the tires when entering the garage????
x2
Yeah, that was my first thought. Asked the current owner when I saw the car - said he had already tried that, at least down to 10psi. Showed me the scar on his garage opening. Assuming any lower there is a good risk of popping a bead out?
Posted: Thu Sep 25, 2014 9:45 pm
E_Swift wrote:edzz wrote:or...
It is my understanding that they are waiting to drive on-board a train that has height limits. The "wheels"
are just big enough to protect the brakes.
