spandit
Posts: 660 Joined: Tue May 18, 2010 5:15 am
Post
by spandit » Mon Jan 17, 2011 6:54 am
Brand new Eberspächer BN4 heater (wrongly listed as a D1L)
Guess how much (and how much is it worth, assuming it works OK?)
Here's me just got my diesel powered heater working well...
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
kpoling
Posts: 164 Joined: Wed Sep 23, 2009 10:09 am
Post
by kpoling » Mon Jan 17, 2011 12:35 pm
Colin: Lucky Find! $24?
Will you install it or re-sell?
Regards, Kevin
Regards, Kevin
'73 710K sold 01/22/2016
spandit
Post
by spandit » Mon Jan 17, 2011 12:38 pm
I might resell it as I quite like having my auxiliary heater run off kerosene as it's cheaper than petrol. I'll sell it to you for $24 but the packaging and shipping will be crippling!
Robin
Pinzgauer 710K
MegaJolt ignition
Posts: 1309 Joined: Tue Aug 11, 2009 12:13 am
Post
by edzz » Mon Jan 17, 2011 1:57 pm
~ £64.00 & delivery
Ed
kpoling
Post
by kpoling » Mon Jan 17, 2011 3:00 pm
Define "crippling" :?:
Regular gas is cheaper than diesel here.
Regards, Kevin
Posts: 1868 Joined: Fri May 01, 2009 1:30 pm
Post
by audiocontr » Mon Jan 17, 2011 3:17 pm
I wonder how difficult it would be to turn one of these into a semi mobile solution? Maybe mounted in a metal box?
Multi-Pinzgauer owners cant afford two =)
Post
by edzz » Mon Jan 17, 2011 3:23 pm
audiocontr wrote: I wonder how difficult it would be to turn one of these into a semi mobile solution? Maybe mounted in a metal box?
I keep mine mounted in a metal box (aka a 710K), and it is highly mobile.
Ed
spandit
Post
by spandit » Mon Jan 17, 2011 4:11 pm
edzz wrote: ~ £64.00 & delivery
Ed
Not even close, Ed...
kpoling wrote: Define "crippling"
Crippling = "more than enough to compensate me for your measly $24..."
It's cheaper here too, but you can run diesel Eberspächers off kerosene/heating oil which is cheaper still. You can also buy "red" diesel for agricultural use which is pretty cheap - huge penalties for using it a road vehicle but perfectly legal to use in your heater.
Robin
Pinzgauer 710K
MegaJolt ignition
kpoling
Post
by kpoling » Mon Jan 17, 2011 6:20 pm
All in all, quite a score. Did you get it in auction or at a local store? Parts for the BN4 are rare or non existent now. Regards, Kevin
Regards, Kevin
spandit
Post
by spandit » Mon Jan 17, 2011 6:23 pm
I sniped it on eBay... should get it later this week. I've seen them go for $500 second hand...
Robin
Pinzgauer 710K
MegaJolt ignition
chacaocop1
Posts: 155 Joined: Sat Feb 21, 2009 10:25 pm
Post
by chacaocop1 » Mon Jan 17, 2011 8:38 pm
Well, let us know when you sell it.... So if this is BN4, I can assume that is 24V, right?
CHACAOCOP
1973 712M
spandit
Post
by spandit » Tue Jan 18, 2011 2:21 am
OK, so you were fairly close...
It is 24V, yes. Will let you know if I decide to sell it
Robin
Pinzgauer 710K
MegaJolt ignition
spandit
Post
by spandit » Tue Jan 18, 2011 3:25 am
I can't believe it but less than 21 hours after the auction ended, it's been delivered! Heavy brute... not sure if I'll have time to unpack it today
Robin
Pinzgauer 710K
MegaJolt ignition
cronapress
Posts: 130 Joined: Wed Aug 25, 2004 12:30 pm
Post
by cronapress » Tue Jan 18, 2011 6:33 am
Looks like you have a good deal there Robin.
Well done that man ! It pays to keep an eye on that fleabay thing. Many a good bargain crops up. I've never had any problems with buying stuff off there.
Tap "24 volts" into fleabay .... hours of temptation !! ha.ha.
Mike.
