Ordered the following: Back Top, Elephant Ears & Curtain only.
Olive Drab material is now in stock by Tuff River. Mine is the first one made in OD color by him. This is also a fire-retarded material just incase I decide to do a BBQ inside the cab
This took us a few hours to do as I have a custom fiberglass top over the cab which needed to be removed. The rest was easy. You need basic tools including a crimper. He provides all new rings, crimps and 45feet of new rubber which is slight bit thicker than the factory top.
The set up I have is that I can do a mesh window to allow air flow or a clear marine grade plastic incase I want light. Pic below.
The adjustable strap system when you roll up the top is so convenient. No more hand cramps trying to hook the top.
The components were all black - black straps, black loops, black grommets etc.
Note: The windows are largers than factory. 4 large removable (plastic or mesh) windows on both sides as there's plenty of air flow.
Recommendation: Order 2 or 3 extra hooks and crimps just incase you mess up on the crimping while adjusting the rubber rope/straps like I did.
Delivery time: 3 weeks approx.
Here are the pics of the process:
The Redcatcher-1 BEFORE
(My buddy Robby )
