Brand new top Problems
I Just bought a new stock top for my 712 but the cord was not long enough to fasten to the hooks. Is this Right?
- pinz1212.jpg (56.11 KiB) Viewed 7159 times
Don't be afraid to do something completely Outrageous. 73 712m Tan, 73 712m Green
Re: Brand new top Problems
looks like you have a bunch of wrinkles in the top still. With the colder weather the cordage might be a little stiff. Looks like the top will lay flat and the cords will stretch to fit fine once it comes up to temp.
its been 70 degrees? The cord is not even close
I count 6 hooks unfastened. Its not even close...
Keep stretching its rubber!!! eventually you will have all the hooks filled...go for the gusto
710M
710M
- David Dunn
Start at the front and lace the hooks pulling the cord as tight as possible as you go, don't leave any slack.... if that doesn't work, get a gym membership.
- Jimm391730
I like to hook every other one first, that helps to even out the tension across the length of the cord. Then I go back and "tighten" it all up by hooking the rest.
I Sent the pic to sav they said it didnt look right. They sent me chord so i fixed it.
Sounds like you've already replaced the rubber, but when I had mine replaced, I could barely get it hooked and assumed it was too short, but they do stretch out, now I've got too much slack and need to shorten them. Did you paint your tan pinz or have you acquired a second one? Hope the scavengers tour business is booming.
Jorgo
24 TIRES
'73 712M
'74 712M
'04 G500
'07 Range Rover
"Those who were seen dancing
were thought to be insane
By those who could not hear the music"
24 TIRES
'73 712M
'74 712M
'04 G500
'07 Range Rover
Ya still have the tan one. I picked this other 712 up in Az been fixing it up. Tours die a bit in december so ive had time fiddle around
Nice lookingo truck! What type and size tires are those? They look great as well! I had the Same problem with my new top. I fired up the shop heater to max and let it warm up really well, eventually all went on and looked good. Good luck!
Maxxis Big Horns 265 75 r16. They ride awesome.
when i bought my new top it was the same thing the sides where too short and then on both sides the rubber strapping broke i barely touched them . im just waiting to order some new ones.
710M 1972
710k 1974
710k 1974
