Door Locks
Posted: Sat Oct 31, 2009 7:35 pm
by totaljoint
Does anyone have experience with the door lock kits sold thru the various vendors? Difficult to put on? They don't look much different than a cabinet lock from Lowes (xcept for the $) in the pictures.
I know it doesn't prevent theft, but I want to keep the lookie loo's out of my cab when it's parked, and the German Shephard is at home.
Thanks!
Posted: Sat Oct 31, 2009 7:40 pm
by totaljoint
Posted: Sun Nov 01, 2009 1:37 pm
door locks
Posted: Sun Nov 01, 2009 7:57 pm
I put them in when I lived in WA. No problem at all, I remember there were very good directions from Scott's website (EI) and other than taking out the inside panels of the doors it was just follow the pictures and go. The first one will take longer and the second is a real snap cause you have done it before.
It can be done with the doors on but I have removable pins so I took the doors off and did it in the shop as it was raining that day. Happens in WA on and off. While the doors were off I replaced the seals as well.
I did put the left lock on the right door but it matters not a wit. They are interchangeable.
Morris
Posted: Mon Nov 02, 2009 7:53 pm
by Erik712m
I was going back through the old thread and noticed Scott Has removed his pics. Is this just temporary Scott?
Posted: Thu Nov 05, 2009 4:47 am
by WolfgangK
As a 'poor man's solution' you can also try this:
- pull back the door panel until you can access the connection of the two rods
- extend the rods by using the alternative holes (M6 screw)
Now your door lever has 3 positions instead of 2:
- 45° angle: door closed normal
- pull lever: door opens
- push lever: door is shut and cannot be opened from the outside.
You can now push the lever flat and close the door from the outside. You can open it only again through the window by reaching the door lever inside....
I am not sure my explanation is clear... but once you look to the door mechanism and try it you will get it
Wolfgang
Locking doors from inside
Posted: Thu Nov 05, 2009 3:14 pm
WolfgangK wrote:As a 'poor man's solution' you can also try this:
Wolfgang
You also need to remove the “screw door lock” if your pinz has it
http://www.pinzgauer.com/showdetails.ph ... o=9011957/ this screw is used to disable the door lock feature. Remember as Wolfgang already mentioned you cannot unlock from the outside if you do this modification and have used the inside handle to lock the door. I choose to leave my driver’s door alone as I know I would eventually lock myself out. The rear side doors on my 710k only required the removal of the screw. Less than 30 seconds to modify the rear locks, now I will have more peace of mind sleeping in back at a zombie infested campground.
EDIT:Same as the front doors you cannot unlock from the outside if you do this modification and have used the inside handle to lock the door
Wolfgang thanks for the posting I couldn’t believe the engineer’s had not provided this feature.
Ed
crcpinz wrote:
Ed, I also have a K and in reading your post I did not understand exactly which screw I'm supposed to remove to be able to lock the back side doors from the inside. I suppose it's a small phillips screw that I would have to drill out (all my door locks have that screw and others stripped), so I just wanted to make sure I pull the right one. Thank you for your time.
Javier
crcpinz asked for clarification so I have added a photo with the location of the removed screw circled in red. Hope this helps.
Ed
Re: Door Locks
Posted: Wed Jan 04, 2012 11:53 am
by crcpinz
Amazing! I now have doors that can be closed from the inside. The mod was done with a Swiss army knife. Thank you Ed (and many others in this forum). You guys are an essential part of the reason I got a Pinz. Cheers to all.
Re: Door Locks
Posted: Wed Jan 04, 2012 1:02 pm
by waterdog
my buddy "BULLET" works fine for me.........
i even leave the windows open......
Re: Door Locks
Posted: Wed Jan 04, 2012 7:54 pm
Waterdog,
You beat me to it! I was going to suggest getting a dog. But your picture says it all.
My two dalmatians seem to attract people - up to a certain proximity. Then they repel them. Hmm... I consider them my alarm system.
Re: Door Locks
Posted: Wed Jan 04, 2012 9:59 pm
by cruzoropeza
I installed electric door lock actuators. Its been working great so far will take pictures later
Re: Door Locks
Posted: Thu Jan 05, 2012 6:55 am
by ScottishPinz
Great tip, screws are now removed and I can lock the doors from the inside! Wish I'd known about this modification ages ago!
Thanks for the info.
Re: Door Locks
Posted: Mon Jan 22, 2018 12:42 pm
by Jake2015
cruzoropeza wrote:I installed electric door lock actuators. Its been working great so far will take pictures later
Anyone have more information on electric door lock actuators?
