Dust Control inside
Dust Control inside
While out camping in the 710M this weekend we noticed a lot of dust entering the back of the truck while driving down dirt roads. We were alone so the air was clear infront of us. The only thing I can think of is that dust was circulating behind the Pinz and entering the gap that is between the tailgate and soft top. Anyone else have this problem and how did you fix it?
- McCall Pinz
Just stumbled across that as well. Anyone ever used one and did it cut down on the dust?McCall Pinz wrote:Yep it definitely sucks in through the gap at the door and covers the rear area. I don't know anything about these guys, but knuckledown production website has a metal angle that fits and closes that gap.
dust in the cab
Saw this advertised several years ago but mostly for keeping out the water, seriously doubt it would do much for dust. Putting down the blackout curtain helps a bit to keep it out of the cab. Nothing is going to keep dust out of a soft top pinz. Go slower.
Re: dust in the cab
How fast was I going?krick3tt wrote:Saw this advertised several years ago but mostly for keeping out the water, seriously doubt it would do much for dust. Putting down the blackout curtain helps a bit to keep it out of the cab. Nothing is going to keep dust out of a soft top pinz. Go slower.
dust in the cab
Really hard to tell...you were in a pinz, right?
Re: dust in the cab
Yeah, slow and steady!!krick3tt wrote:Really hard to tell...you were in a pinz, right?
I have my reserves about ordering that plate from knuckle down. I just don't think it's going to make a very good dust blocker. I'm going to try some ideas and see if I can cut back on the dust getting into the back.
dust in the cab
I think the KD angle product is OK in its idea.
The issue I saw with installing an angle at the back door is that the canvas has to be lifted to either open or close the door. I placed a piece of angle that I had lying around to see how it would work and I decided against it.
The idea was to install it when I lived in WA and there was so much rain, and I noticed the pressure draws the water in at the back. It also draws the water in at the doors in the cab. I purchased the deeper window sills from SAV, they don't do much either.
I used a peice of black angled plastic from home Depot for the front edge on a wood step like the one shown in Fleg's picure. It works great at keeping the rear curtain in place, flexable so I can lift the rear curtain over it when needed, but yet keeps the rain from running in. Best part is was cheap so if it breaks no big deal.
Scooter
Scooter
Re: Dust Control inside
Fleg wrote: Anyone else have this problem and how did you fix it?
Yes we all have that problem Hard top. Fixed it! When it was a softtop I put a one inch thick piece of weather striping on th bottom of the softtop. It help a little bit some dust still came in.
Wow, no one else thought of this before me ? easy solution.. don't go on dirt roadsFleg wrote: we noticed a lot of dust entering the back of the truck while driving down dirt roads.
but where is the fun in that... I tried many things with my 712, and could never stop the dust, but I like the "tonneau cover in the back bungee corded to the sides." idea, or an extreme would be to put velcro on the edges, but I thnk that would look yucky
Pinzing is AWESOME.
norcal pinz
Would something like this work?
Dust Deflectors
Alloy Deflector
http://www.roofrack.com.au/viewproduct. ... 1&subcat=7
Though guess that how much air "flows" over the top of a Pinz is debatable . . .
Alloy Deflector
Stuck in the bureaucratic spin cycle!
