When I bought the Iltis, one of the first things I did, after getting rid of the Michelin XL tires, was add a stereo. Since I still have the Shark 250w, FM/AUX/MP3/SD, 12v motorcycle stereo I bought for it, I wanted to try and get it to work first before I went the route of the AMP board others have used. In the Iltis I used a Battery EQ to get 12v, but since I probably hurt the batteries with
my install, I wanted to stay away from that altogether. Since the 24v-12v step down unit, which plugs into the Pinz 24v DIN connector, is working so well for my GPS, I wanted to use it. The power cord for the the Shark has a plug on one end, and a split wire on the other, which allows you to tap into a 12v source and ground. I wanted to leave this intact for my Ural, so I went searching for a used accessory connector and cable that will work in the Shark...and I found one at work. A colleague of mine had an old coffee cup warming plate that broke, and didn't need the cable any longer..and it fit the Shark! Here are two videos, one of the radio and
converter, and the other with the engine running and the volume bumped to 50% (iPhone video). Now I need to figure out where to place the stereo. I used Velcro so that I can remove the unit when I need too.
