Eberspacher BN4 Questions
I recently aquired a BN4 heater out of an 712. I need a 24V fuel pump to get fuel to the fire. Anyone have a part # or recommendation for this application?. Its pretty much the last piece of the functional puzzle to get it working. However, ive also heard of someone on here using the factory fuel pump for the truck and simply putting a "y" fitting inline to supply both the truck and the heater simultaneously. I dont necessarily like that idea. It may work, but it doesnt sound safe or reliable. Thoughts?. Ideas?.
Thanks.
Tyler
Thanks.
Tyler
1975 710M
2016 Ram 2500
2016 F-350 Superduty
32’ gooseneck flatbed
1981 M111 welder trailer
2011 M101A1 trailer (sold)
2016 Ram 2500
- westernair
Re: Eberspacher BN4 Questions
Bn4's were used in VWs as well. Might just use a 12 v from a VW and get your power from you 12v converter for it.
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
ebay germany right now:
http://www.ebay.de/itm/Pumpe-fur-Standh ... 500wt_1268
may ship to USA if you ask, but unfortunately seems to not accept paypal...
- westernair
Q good find, I don't think these come up to often, I would get it.Q wrote:ebay germany right now:
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
I've got a complete new BN4 to sell if someone wants it - no takers on eBay recently
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Robin
Pinzgauer 710K
MegaJolt ignition
- westernair
Yours for sale, is it a military 24v unit or a 12v civilian unit?spandit wrote:I've got a complete new BN4 to sell if someone wants it - no takers on eBay recently
Is is complete with the special pieces to vent out the side plate and run heat to the back?
Lastly what are you wanting to get for it?
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
It's a military 24V unit but designed for a Land Rover so to draw air from the side would need a mod. I was looking for £350 but open to offers
Robin
Pinzgauer 710K
MegaJolt ignition
Robin
Pinzgauer 710K
MegaJolt ignition
found this one on eBay: BIN for $400. currently no bids at $300
http://www.ebay.com/itm/Eberspacher-vw- ... es&vxp=mtr
-Rick
-Rick
ranicotra wrote:found this one on eBay: BIN for $400. currently no bids at $300
-Rick
That one is 12V. Mine is 24V and new (unused)
Robin
Pinzgauer 710K
MegaJolt ignition
Robin
Pinzgauer 710K
MegaJolt ignition
- audiocontr
I'm confused.
The stock Heaters had an external 24v pump? Where is it mounted on a K?
On my K the electric metering pump is installed behind a panel in the right front wheel well by the tank. When the heater controller is calling for fuel, you can feel or hear the pump ticking if you listen closely. But then again my heater is a slightly different model B3LC used in the factory refurbs. There is a spec for volume of fuel over time in the Eberspacher manuals and the pumps are set at the factory. Otherwise you get smoke or flame outs.audiocontr wrote:I'm confused.
If the pump is not ticking, or the tank is low on fuel, or the pump is not metering fuel, you won't get heat. The supply lines from tank to pump in mine had to be replaced, then there was heat.
- audiocontr
thanks!
