3saurus/Battleborn rear bumper and "Fuel Mule" carrier
Posted: Wed Mar 04, 2020 3:55 pm
After identifying a number of shortcomings with my previous bumper/carrier combo I got with 3saurus in Las Vegas to assist me with a more functional redesign of this familiar tire/fuel carrier configuration. Below is a list of improvements over the previous design:
- Divorced carrier design allows carrier to be removed/serviced independent of the bumper. This also means that you DO NOT have to modify/replace your existing bumper to add one of these carriers to your Pinz.
- Reduced carrier swingarm length minimizes leverage on hinge AND keeps the carrier better within the profile of the truck when carrier is in the open position.
- Relocation of hinge inboard of rear suspension significantly improves weight distribution of the open carrier across L/R rear suspensions (vs driver-side only. The previous carrier crushed my driver-side rear springs
- Heavy-duty 1 3/4" hinge spindle.
- Simpler service access to carrier hinge.
- Closer fit of carrier to rear profile of the Pinz places load more directly inline with the hinge.
- Elevated tire position preserves factory departure angle.
- Integrated fuel can retention brackets eliminate fumbling for a place to hang/store brackets while removing/replacing fuel cans.
- Heim joint allows carrier to swing open/closed with rear door
- Quick/detent pin at heim easily releases rear door from carrier for fuel can access.
- Remote carrier lock pin lever releases lock pin from the latching edge of the carrier/door rather than at the hinge mounted pin.
