Surfboard/Kayak Racks for a 710M?
Actually for paddleboards (12 - 14 feet) and a surfski (21 feet) . . . Any ideas on a good rack set up. Would prefer removable since I'm guessing I will have only an inch or so of clearance in the garage (this would make a permanent rack attached to the rub rails a no go). Thanks for your thoughts!
Stuck in the bureaucratic spin cycle!
I bolted these brackets to the roll bars fore and aft and used standard rain gutter cross bars (as in picture) to make a rack to carry my landsailer. when you take the crossbars off there is no height increase.
http://www.amazon.com/Yakima-Wide-Body- ... B000RRSII2
If you do it this way you have to be sure you mount the brackets high enough on the rollbar that the crosspiece clears the top with the particular crossbar rig you are using.
My avatar shows my rack. And a bigger picture is here:
http://swpinzgauer.org/message_board/vi ... 668dae54c6
Steve
Steve
