seatbelts for rear benches
They didn't get that way for free!
1974 712M - sold
1973 710M - sold
1974 712M - sold
1973 710M - sold
I got the E-trac installed. Thanks to everyone for there input.
I used Dupli Color Truck Bed Coating on the E-trac. Fast and easy!
I installed the E-trac with 10 grade 8 bolts drilled thru the uprights. I used appropriate washers front and rear. Make sure you space the E-trac up from the bottom. This will help with assemble of the bottom bolts. It will also allow the seats to fold over with out hitting the E-trac. My seats clear the E-trac when folding over, but do not clear the seat belts if they are mounted. In other words I have to remove the seat belts to fold down the seats. Not a big deal. Just a heads up.
Four seat belts per side. I am using a Redoxx bag to keep my seatbelts in when they are not installed. Fits perfectly between the forward rear seat and the cab partition.
Justin Pitcairn
2013 Jeep Wrangler Rubicon w/
Ursa Minor J30 Camper
Instagram @pitcairnoverland
I like the idea of bagging up the seatbelts wshen they're not in use. Of course you need a pretty big bag for 12 belts! Cleans things up considerably even if you once stash some of them. Good idea...
1974 712M - sold
1973 710M - sold
1974 712M - sold
1973 710M - sold
- totaljoint
I found these light weight ammo style boxes for my seatbelts, intercom headsets, first aid kit and manuals:
5 across is a perfect fit behind the bulkhead, and still allow the seats to fold down.
They are held on with 4 or 5 quarter sized neodynium magnets/box. (3 on the lid and 2 on the base, I didn't want to drill mounting holes so to remain air tight.)
Magnets hold secure even through the Rhino liner, but a good tug will release the magents.
Got mine a sportsmansguide.com, but are now on e-bay:
http://cgi.ebay.com/Military-Surplus-Ca ... 4835e9e370
The foam liner comes out easily with a heat gun and mineral spirits.
That's where I have my door top rack installed ("nice rack - II" posting) but there's probably room on the passenger side. Excellent idea and suggestion!
1974 712M - sold
1973 710M - sold
1974 712M - sold
1973 710M - sold
