Does anyone have any info on the steering shaft for at 71* series Pinz?
Trying to find if shaft is round, D or double D shape?
Any info helpful
710/712 steering column/shaft pictures/info?
- Jimm391730
Re: 710/712 steering column/shaft pictures/info?
Check the photos I put in the Tech section when I rebuilt my 712 steering box, see if your questions are answered.
PM me your email and I'll send you the manual. Looks round
'76 710K
- Jimm391730
If you are talking about the shaft that the steering wheel attaches to, it is a one piece round shaft with the splines for the wheel at the top and the worm gear at the bottom, complete with ground-in ball races for the bearings. The splines for the wheel do not have any index (a missing or wider spline), the wheel can be put on in any orientation. I did not take any dimensions when I had mine apart, sorry.
Thanks!Jimm391730 wrote:If you are talking about the shaft that the steering wheel attaches to, it is a one piece round shaft with the splines for the wheel at the top and the worm gear at the bottom, complete with ground-in ball races for the bearings. The splines for the wheel do not have any index (a missing or wider spline), the wheel can be put on in any orientation. I did not take any dimensions when I had mine apart, sorry.
