Brake Master Cylinder C306
959gav
Post by 959gav »
I need to replace or repair the Brake Master Cylinder on my C306, But I'm having a spot of bother finding parts or kits!
Like with the wheel cylinder is there any Rover parts that I can use? or are there and repair kits that don't take the mick price wise?
Gav
wrangler_tj
Re: Brake Master Cylinder C306
Post by wrangler_tj »
First what's the problem with the brake master cylinder?
Alos take it out of your Volvo and measure it up. Lenght and inner diameter.
Probaly you can take one of a Volvo 164 with hydrolic brake assist.
If you have it out of your Volvo let me know the brand and number on it,
than I can look it up for you and tell you how to find one.
959gav
Post by 959gav »
Thanks for the reply
Well all the Wheel Cylinder where basically seized, so when when looking at the Master Cylinder I could see it has had a fluid weak. So now I'd like to at least replace the seals.
I'll take it off and come back with the relevant sizes etc
959gav
Post by 959gav »
The Master Cylinder is a
FAG 55204 34 then 28
Bore is 31mm
Length 217mm
And it's going to need to be replaced
Doccers
Post by Doccers »
959gav wrote:The Master Cylinder is a
Bore is 31mm
Length 217mm
http://tatanka.nu/50_Wheel_Brake.asp
959gav
Post by 959gav »
Tatanka might be selling original parts, but there's no way I'm spending over £700 for a Master Cylinder!!
Post by Jim LaGuardia »
I hope you realize there are also 2 remote hydraulic brake assist cyinders on the boosters as it is a diagonaly split braking system.
They are not cheap. If you have brake fluid dissappearing, you will find it in the boosters. I pulled at least a liter out of the 1 bad booster I replaced on Greg's 303.
Cheers, Jim LaGuardia
"Arch Magus of Machines."
