Parts for volvo C303 portal axles
Posted: Wed Apr 21, 2010 8:37 pm
by timcj408
Hi,
I have a CJ7 Jeep with Volvo portal axles and in Australia I find it hard to get parts and I am hoping someone can help me.
I am after CV boot, large outer oil seal for the stub axle and retaining nut for the stub axle and tie rod ends for a right hand drive.
Hopefully someone can point me in the right direction.
Thanks.
Posted: Wed Apr 21, 2010 11:49 pm
by lindenengineering
timcj408
I have them, and if you pm me I can do a search for them.
Equally I can find you the part number and you can see if Volvo Trucks (the big stuff --like road trains etc) Down Under in your State can get them!
Cheers Dennis
Hmm Crikey--- thinking of a Castlemain! :wink:
Posted: Wed Oct 27, 2010 11:01 pm
by Argen
Yes, i'm interesed on it too!
It would be great to know original partnumbers for common details of portal axles: bearings and seal oil rings.
To ask the regional Volvo truck dealers.
Posted: Thu Oct 28, 2010 1:30 am
by wrangler_tj
I also can arrange parts if needed.
In Belgium Volvo Trucks can get the parts if on stock.
The CV boot originally isn't good. You can get newer from online shops from wich the quality is better.
I recommend www.omt-offroad.com.
Posted: Sat Oct 30, 2010 12:04 pm
by Argen
That's what I found:
http://www.volvo4x4.com/tech/parts/bearings/
Volvo c300 portal axle bearings/seals
bearings:
Drive gear (upper/small gear)
SKF/FAG 6210 (single row radial ball, open) - dims: 50x90x20
INA BK4520 (drawn cup closed needle bearing) - dims: 45x52x20
Driven gear (lower/large gear)
Timken JLM104948 (tapered roller/cone)
Timken JLM104910 (tapered race/cup)
Timken JLM508748 (tapered roller/cone)
Timken JLM508710 (tapered race/cup)
seals:
CR 23451 (STEFA, BB - dims:60x85x8), upper portal/axletube oil seal
CR 19687 (STEFA, BB - dims:50x90x10), inner hub grease/oil seal
STEFA, BY 80x92x28 (pn#32896 1) - outer hub grease seal --
*this is the impossible to find seal.
Also
http://www.freewebtown.com/adventures/miscellaneous.htm
