Has anyone ever flowed the heads?
Posted: Sat Feb 26, 2005 5:14 pm
Just got back from driving the C306 Fire Rescue truck. All I can say is WOW!
Ok, it's no speed demon. FOR NOW. But it's a stout six cylinder four speed that has tons of potential on many different levels.
The engine ALONE is begging for many upgrades. Exhaust is but one. Air cleaner and intake manifold.
Sending the heads out to have hardened seats for unleaded use. NEW valves with possibly larger valves installed. PLUS flowing the heads will work wonders. That, combined with a different bumpstick...
This could increase hp to around 200 hp as a minimum. I think the rest of the parts could withstand that, but would have to completely inspect EVERYTHING before doing all these changes. Perhaps an aftermarket OD unit that could give a really good drop in revs, thereby making this a killer highway vehicle. The OD could be put in line with the rear drive axles ONLY, so that IF you wanted to 'lock her up' in 6x6, just make sure the O/D was in the 1:1 position. Otherwise, anywhere from .50:1 up to about .75:1 would give a much better upper end. And I don't think you would actually LOSE anything from the off road side, as long as OD was still in 1:1.
With a few other tricks I and my mechanic have up our sleeves, this COULD be a killer truck.
Again, on many different levels.
SO, WHERE AM I GOING WRONG???
