Hafi Heavy Cleaning - lots of photos
All the black drive line parts are back from powder coat - time to start putting it all back together (just need to clear the tranny and diff's).
Should be done in only a few more years :)
Hafi 1 Mine Restore7.jpg (4.28 MiB) Viewed 1485 times
More
Focus is only on driveline - need to get something put back together!!
Hafi 1 Mine Restore8.jpg (4.82 MiB) Viewed 1457 times
Looks great - what did you do to clean the parts?
Haf-e wrote:Looks great - what did you do to clean the parts?
Thx - Aluminum Brightener from Caswell Coatings (Caswell Plating in the US)
The never ending restoration finally has a tiny update :)
After getting some motivation from seeing some other Hafi restorations, I figured it is time to start moving this forward before I forget how it goes back together!
-15 Celsius, so I just did a small fix to the speedometer.
The original one was replaced long ago but I was able to get a nice Pathfinder unit from Soni in AZ a couple years back.
The center cap had come loose so took it apart and fixed it.
Not 100% sure how many miles my Hafi has on it. I think Jim L said it had under 3000 miles when he replaced the broken OEM unit with a VDO one. The VDO one has 450 miles on it... I may adjust this speedo to 3450 or perhaps 00000 (or just leave it)?
Thoughts?
Only reason I would do 00000 is to start fresh after the full restore but not even sure if that is legal??
Hafi 1 Mine Restore9.jpg (88.75 KiB) Viewed 1412 times
Post by stiffler4444 »
Pretty sure it's never legal to adjust an odometer, but it's not like you're trying to sell it tomorrow with "accurate miles". I would set it for my own satisfaction and be very open and upfront with any potential future owner.
