Work has started on the rear FRame see the arrow
The kitchen area layed out with 4 boxes. The farest away box will be a slide out draw for the cookers.
The cockpit with the air cond unit under the passenger front
The pilot seat with the mockup dash sitting in it. It will all be lifted about 50mm and the left side about 100mm during the rear dash makeup.
Over the weekend - Saturday I arrived at the workshop 11.00am and left 4.30pm
We discussed over 5 hours so much stuff
1. I sat in the pilots seat and we put a seat in and sorted out the DASH position and what it will look like - next time I go up a blank new DASH will be made which will allow any control to be reached while wearing the harnessss seatbelts. sinx im 6' 2" it has to be correct for me and the SHORT friends who will drive it. as it is a small very cockpit and we are not changign thelayout at all.
2. We discussed at length the new pipe bending machine (the quality of the bends is unbelievable not one crease) and the location of all components of the "ROOF RACK" the KAYAKS have to fit somewhere and the design completely including position of LED LIGHTS hanging off it. After watching a MAN DIESEL in the BRESLAU and a few VOLVOS (all cabovers) I changed the location of the LED light rack to on top of the roof as all VOLVO''s go a long way into the water/MUD on entry - oops (usually up to the bottom of the window). The whole roof rack will be tacked together in 2-3 weeks ready for my viewing.
3. The LED lights will allow FLOW of air over the roof to the RADIATOR scoop and INtercooler SCOOP.
4. The positioning of recovery kit was decided and including the highlift JACK and shovels etc
5. I cut and fitted the rear cabin panel then we looked at it and BRett said I can make it easier and nicer we use the new alloy composit material - he showed me and im hooked 3mm thick and LIGHT as and easy to work and even easier to clean and it will lighten up the CABIN - same for REAR CABIN also. The outside of the rear cabin will also be same material means I do not have to paint it - colours we are thinking of are GREEN or RED or bright PINK .
6. All electrics apart from the WINCHES and the STARTER and alternator will be 12Volts a 12V alternator to be fitted soon - I will now proceed to order all the parts slowly there is a list of about 30 items to be purchased - List later im still flabergasted after I starting writing it out
7. The rear cabin will be totally ALLOY protected by the "ROOF RACK" - man it will be light I estimate under 100kg. It will also be prepainted as it comes in COLOURED allow so all I have to do is pick the colour I like (BRIGHT YELLOW) and thats the final lCOAT . Then the cabin has to be paited to match only. Saves me about 2-3,000 in painting the rear inside and out.
8. 1 Month has been allocated to do the wiring alone.
9. Position of everything inside the cabin worked out Wiring BOX will be on the roof and flip down and a full length console for securing stuff. Air conditioning controller already installed.
10. Radio and VHF will be on the roof.
11. KILL switch for everything will be in reach of both PASSENGER and PILOT.
12. Rear floor will be wait for it a PLASTIC FLOOR - LIGHT 10mm thick and everything proof - it comes from NZ and is for CHEMICAL cabinet making More on this one later.
13. We discussed painting and underseal and soundproofing. Once the cabin is finished it will be removed and sent to Kuala Lumpur once I find a place to underseal it here. Then take it back to IPOH (it may even be painted in Kuala Lumpur first also since we only have to colour match it to the rear external panels). Then the internal soundproofing can be installed and then the alloy finishing and the fitting of the dash and the overhead consoles and the wiring can be completed.
