I wanted to make it into an expedition vehicle, and my plans have steadily expanded.
I did initially plan something like this example:
It already had a diesel conversion, power steering and a few other enhancements when i bought it, but needed a lot of tidying up. The Diesel was D24TIC from a Volvo 940, so not the quietest smoothest motor.
I had recently acquired a semi-decent alu/zinc replacement front cab, and am half way through painting that.
In the meantime i decided to change the motor for something more modern, quieter, smoother with more power & more economical - a OM606.962 which has been extracted from a E300 Merc.
And shoe-horned into approximate position:
So i'm currently in the process of making up new engine mounts and the gearbox to transfer box coupling.
I will stick with the Merc 722.6 electronic autobox, it supposed to be a superb and reliable unit. And rightly or wrongly i will keep the Om606 under ECU control. Have the whole loom out of the E300, just wading through it to see which bits i need to keep.
It will also get converted to discs, probably with CTIS. And i did have some musings on installing the ABS system from the donor Merc.
In the meantime the plans for my expedition vehicle have expanded. I'm going to get rid of the old rear body altogether and build a custom camper body. This will get me something larger & more fit for purpose. I plan to do it in steel box frame & alu panels.
Here is my latest model:
- Cab is in the process of being painted
- I've put in the hinges and pads to allow it to tilt up for access to the engine, just have to source a hydraulic cylinder and pump.
- have the foot handbrake installed from the merc donor
- started to make the ECU wiring
- Painted and fitted the upper cab
- Started on the rewiring
- Made new dash & switch panels
- Constructed a battery & compressor box
- Cab latch and support frame made
Pics below:
Cab top fitted
A nice set of new wooden bump strips
Comfy Audi seats, and the new dash panels
Auto shifter, hi/low, and difflock controls. Gauges are Vac & OBA pressure.
It's alive!!
Dual battery and compressor box
An Iveco cab latch and support frame
The modified inlet manifold under construction
-New inlet manifold welded
Eberspacher installed, Nice new yacht hatch fitted
The coupling shaft.
assembly
And fitted in place
