Have been driving my pinzgauer 718 p90 incrementally, working out bugs and such, and recently tried taking it on a trip.
45 mins into the trip, temp climbed and touched the red, I pulled over immediately and as I did, a hose burst, leaking what should have been coolant everywhere, but instead started with what seemed like a couple quarts of oil.
The oil cooler is/was brand new, the radiator is upgraded aluminum unit, it has a new turbo, new head gasket as well.
My question is, is there another place somewhere in the engine or cooling system where oil could mix with coolant? All research I have done points to the oil cooler, but seems iffy since it's brand new.
Any input is appreciated, thank you!
Oil in coolant
Oil in coolant
1990 718MW. Work in progress... (like they all are.)
- David Dunn
Re: Oil in coolant
Oil cooler failure would have been my first guess. . Next would bee the head/head gasket
Just for reference, which hose burst and does your truck have the coolant afterrun pump ?
Is there coolant in the sump?
