Wheel offset?
Anything DIESEL driveline, axle, suspension related goes here.
Sethsquatch
Wheel offset?
Post by Sethsquatch »
Hey all!
So finally getting to use my Pinz as it should be, getting it off road and camping in it. Just wondering if it's possible or advisable to put a wheel with a different offset on a 718.
I'd like something to give it a little wider stance for stability and looks. Nothing radical, but maybe 1.5-2 inches. I know I can get custom wheels made to order, and from what I can see, there's nothing to rub on. Please give me input. Also, if this works, I might have 7 factory wheels with brand new KM3s on them. :D
1990 718MW. Work in progress... (like they all are.)
Joeri
Belgium
Re: Wheel offset?
Post by Joeri »
Well i have mentioned it beefore...i have ssangyong alu rims on mine and they fit perfect and give you a more wider stand :!:
Sethsquatch
Re: Wheel offset?
Joeri wrote: Thu May 20, 2021 12:54 am Well i have mentioned it beefore...i have ssangyong alu rims on mine and they fit perfect and give you a more wider stand :!:
Do you have pictures?
How much is your wheel offset?
Joeri
Belgium
Re: Wheel offset?
Post by Joeri »
The track is 1m 84 cm wilde...outside tyers.
Tyers are bf goodrich mk2 255/85-16.
Rims are alloy ssangyong REXTON 5x130...ET-43
Sethsquatch
Re: Wheel offset?
Joeri wrote: Thu Jun 03, 2021 12:55 am Image
Tyers are bf goodrich mk2 155/85-16.
Looks good!
Whats the difference in offset per wheel if you know?
Joeri
Belgium
Re: Wheel offset?
Post by Joeri »
Well the original td steel rims are ET-73 , so the difference is 30mm ( 1, 18 inch) pro wheel outwards . :wink:
So your stand is 60mm ( 6cm) or 2,36 inch wider on the axle.
When mine stands straight the tyers are fluch with the outside wooden rails.
