718 wheel bearings & seal
Posted: Wed Oct 15, 2014 8:23 pm
So, somewhere around the 2,000 mile mark, on my way back home from buying my new 718, I noticed that I had a leaky rear portal. I ended up trailering the Pinz the rest of the way so as not to cause further damage. Once I got home I immediately called around asking for replacement parts. A vendor sourced one for me, but it was supposed to be two weeks out, and the bearing was to cost $190.14 and the seal $38.51!!! About three weeks after that date came and went, the parts finally arrived. I decided to see if I could match the parts locally, for the next time......here is what I found; Same bearing $67.32! Same seal $7.00!!! These parts are available from Gulf Bearing of Dallas, TX. Below is the contact info for the company I just ordered four of each from.
I am all about supporting our local (USA) vendors, but NOT at the expense of throwing away money just for their sake. I know I am not the only one, as evidence by the numerous postings with crossover part numbers, so flame away if you must. Those of you who are looking to save some $$, I hope this helps.
Motion Industries, Inc
Bill Wilson
(505) 884-2606
-Outer Wheel Bearing Part # 9006245 (use RLS16 when ordering from Motion Industries)
Size: 50.8x101.6x20.6 (2"x4"x0.811", it is a British part, which is why it is in inches in the book)
- Outer Wheel Bearing Seal Part # 7161340461
Size: 70x90x10 (2.7559"x3.5433"x0.3937")
I was told that the front outer wheel bearing is the same size/part #, but do not know personally. If anyone has changed their front, and has the numbers (or wanted to send me the old/bad one), I would be happy to take it in and verify.
I just wanted to thank NJ718 for the part # on the bearing way back in August!!
Take care,
Phil
Bill Wilson
(505) 884-2606
Take care,
Phil
