Replacement speedo or fix broken one??
Our speedometer has just packed up after a very long dusty corrugated track. started with needle bouncing around, then a click click click that varied with speed ( i thought cable broke) then needle jumped sporadically and the miles on the clock werent rotating??
checked cable and i have drive through to speedo.
removed speedo and manualy turning the drive the needle moves but not how it should, if you half turn the drive, the needle turns half a turn and quite often sticks there. a gentle tap and it slowly returns to zero. i hace attached a electric screwdriver to allow a very slow constant speed. but the needle seems to have a mind of its own and sometimes comes right round past 90 mph!!. there is no noise of broken teeth in the gears that i can detect and was hoping it was just dust in there. I have blown compressed air through with a little improvement but not sure if dust is cause. Can they be repaired ?? I would put a new one on but as we plan to sell her very shortly Iwould think it would deter potential buyers.
Any thoughts out there on best way forward?
Thanks in advance
Ty[/u]
Thanks in advance
Ty[/u]
info on pulling a vdo apart
http://www.pelicanparts.com/techarticle ... repair.htm
apparently can get replacement gears for inside
Regards
(Project Gimpy 2)
(Project Gimpy 2)
No worries as your on a trek I thought get you as much help as possible.
My folks live in Kalgoorlie and I have done the gunbarrel highway from ayers rock to Wiluna which is an adventure. Nevr got up to cape york.
Jenolan caves are awesome. I am hoping to have my pinz down there next January. How the locals looking at the Pinz?
Regards
(Project Gimpy 2)
(Project Gimpy 2)
- westernair
If you struggle with the repair yourself. Orange Empire Instrument out of Los Angles CA can do the work. Only the finest workmanship around.
I can get you the contact info if you need it. I have a rebuilt speedo in the garage that should have their phone number on the box.
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
Tyron,
I did an VDO electric speedo conversion on my 716. I've done 4 conversions on SDP trucks ( Pinz 710, 712 , 716 and Haf 700) and the only one I have had problems with has been the Haf. In Oz, a Hall sensor in metric shouldn't be a problem, and VDO electronic speedo , a piece of cake too... The TDs use a smaller diameter speedo than the 710/12. Installation and programming is simple, plus you can reprogram for different tire (tyre
) sizes.
Dave
Dave
thanks for all the help. I have found a place in victoria that can repair ( but waiting for quote) will look into electronic conversion, depends on cost. Im a bit gutted as im worried a new speedo might put off buyers??
Oh and everyone loves my Pinz here, a few who know the score call them "Zingers". I hadnt heard that before! Lots of interest and encouragement for what we are doing.
Thanks all again
Ty
If you get out here in your pinz it would be great to meet up, mike. keep in touch.
Thanks all again
Ty
Re: Replacement speedo or fix broken one??
At last my speedo has been repaired at howards instruments in Victoria at a price of $135 including GST and shipping to darwin. Very pleased with the result.
Thanks for all the input.
Ty
Ty
My speedo went out on the return from NWMF. The needle shows speed but the numbers do not change.
Mostly I use the GPS for speed as I have larger than stock tires. The stock speedo is at least 10% off.
Is this a remove and replace or is it a take apart and play with it? I am fairly sure a new one is spendy but a used
one might give me the same issues.
Take it apart and play with it. I’ve fixed a couple that had the odometer quite functioning, not hard to fix. Takes a little effort removing the bezel without damaging it and the lens can be a pain to get unstuck. All that said I now have spare mechanical speedometers as I have installed a VDO electronic speedometer. So cool having it read out in mph, no more little pieces of tape or doing km to mph conversions on the fly.krick3tt wrote:My speedo went out on the return from NWMF. ~ ~ Is this a remove and replace or is it a take apart and play with it? .
