I’d like to install it on my 710K, but the problem (of course) is the fact that it’s a 12 volt winch.
The winch says that it needs a battery with a minimum of 650CCA to operate. (Cold Cranking Amps?)
So, here’s the million-dollar question(s):
Would a simple voltage reducer be able to provide power to the winch?
(I’ve been operating under the assumption that those were used primarily for accessories)
If this would work, I'm also assuming that power is not an issue because of the dual batteries already in use. (Is that correct?)
OR
Is it possible to add an additional battery that can be used to power the winch?
- The bonus here would be the ability to use other 12V accessories without the need for a voltage reducer.
If so, could anyone explain how this is done? (For instance, is the new battery charged off the alternator? Does it need its own separate alternator?) I’m truly boggled at the possibilities.
![Confused :?](./images/smilies/icon_confused.gif)
I’m sure this has been done before (and possibly discussed at length on this forum). If anybody has a link or some plans they’d like to share, I would be very grateful. In fact, if you live near Denver, I’ll buy the first couple rounds for a quick brain-dump on the subject.
![Wink :wink:](./images/smilies/icon_wink.gif)
Thanks!
(Sorry if I got rambling here...)
