Engine compression
Locked
bernhard
Engine compression
Post by bernhard »
What is the compression of a Good Pinz engine in PSI? Both my Pinz measure 160-163 PSI. I’m guessing this is fine but just wanted to confirm with other owners out there.
Bernhard
Bernhard
1973 712M
1975 710K
2013 Tacoma TRD 4X4
Post by Jim LaGuardia »
That is the top end of the scale, I find most to be around 125-145psi :shock:
Cheers, Jim LaGuardia
"Arch Magus of Machines."
hkmp5
Post by hkmp5 »
Hello Bernhard,
My pinz engine runs between 150 to 155 psi.
bernhard
Post by bernhard »
Thanks guys,
Looks like both my engines are in good condition. :D My 712 always pinged on regular gas so now I run supper or supreme. I was under the impression you could run these engines on very low octane gas? I guess what is considered low octane in Europe is high octane here.
Bernhard
1973 712M
1975 710K
2013 Tacoma TRD 4X4
2012
Post by 2012 »
don't you just have to retard the timing a bit to use 87 octane?
Charles
Post by Charles »
Hi Guys,
That seems like pretty awesome compression to me! Last time I did a leak-down I had compressions of about 145-150ish (with a cold engine though)...
Also, I've been running 87 octane in my Pinz for a long time with no ping/knock at all (and I am a scooch advanced in timing). I do have the civ ignition / spark though so maybe that makes a difference as well.
Best Regards,
Charles
('73 710K)
PS: Keep your stick on the ice
Locked
