Oil Filter cross number for the U.S.
Been trying to pull up the site with all the cross reference part numbers but it wont load for me - need a cross reference part # for the pinz oil filter - I assume the Fram # on the filter is a good one here in the States.
Home of the SHTF50 and SHF/R50 .50 BMG Rifles
Filter cross ref.
I have never found a Fram that fits in stock anywhere. I always use the Napa 1768. The local store keeps one in stock for me. Here is a link to a filter cross reference.
http://www.rmpinzgauers.org/pinzgauerstuff.htm
Did your distributer ever dry out? I have run a small bead of silicone around the sealing area of the cap and have not had a problem with water since. Glad you made it this weekend.
Fram 36A Fram PH2842, If you haven't already checked it out here's a link to the Yahoo group http://groups.yahoo.com/group/pinzgauer/ there is loads of info.
Just get in and go....
wet dist cap
Wayne,
Had a good time - to bad its so dry in the green swamp. Once I found the wet cap and sprayed some WD40 in there all is well. I still have to get a long plug socket to tighten the one plug that was loose. I will try the Napa # here and see what they have. Looking under the truck yesterday I found a oil leak running down the right rear tire. Gear oil from the smell - so thats another thing I have to do.
Walter
Walter
Filter #'s
Mark Pinz,
Thanks for the info - off to the store.
Walter Keller
Walter Keller
filters
Well I went to NAPA with the numbers (Napa #'s) from the yahoo site and they had all both filters in stock. Kinda pricey but I guess that goes with having the pinz.
filter numbers
Jim,
Thanks for the numbers - more options is always good. Went with the larger Napa oil filter.
Walter Keller
Walter Keller
MANN Filter Qriginal Equipment Oil Filter
The original equipment MANN Filter is actually the W940/5. The W940/29 that Jim listed is actually a Porshe filter but will mount and work on the Pinz. The OE filter has the wrench attachment on the end to ease service in the field.
Mit freundlichen Grüßen / Kind regards,
- Stu Miller
Manager, Design & Development
MANN+HUMMEL USA
phone: 269-329-3944
email: Stuart.Miller@mann-hummel.com
- Stu Miller
MANN+HUMMEL USA
phone: 269-329-3944
Hello Guy´s
here are my cross referent list for Petrol Pinzgauer´s. Like the TD list´s i can´t get any warrenty if the filters fit´s. Filters from Mann ,Fleetguard and Knecht are tested and they fitts.Also this list is made of cross-refernt lists from SF-Filter,Hengst,Knecht and Mann.
Oilfilter
SDP Nr 710.1.07.033.2
AC: PF14 , PF 32 , X2 , X21 , X29 , X47
ADL: ADI 32101
Bosch: 0 451 104 003 , 0 451 106 065 , 0 451 203 061 , 9 457 280 530
Coopers AZL 055 , Z66
Crosland: 640 , 319 , 660
Digoema: DGM/0 940/5
Donaldson: P52-8220 , P55-3411 , P77-9149 , P55-2297 , P55-2819 , P55- 5680 , P55-9418
Fiaam: FT 4790 , FT 4653
Fleetguard: LF 3402 , LF 654
Fram: PH 1 ,PH12 , PH 2802 , PH 2827 , PH 2815 , PH 2840 , PH 2858 ,
PH 2881, PH 2996 , PH 3569
Hengst: H17W01 , H170/1W
Knecht: AW 5-2 , AW42 , AW 512
Knecht/Mahle: OC 59 , OC 61
Kolbenschmidt: 154 05
Luberfiner: LFP 2538
Mann-Filter: W 940 /5 all other / (x) don´t Fit or have other overpressure
times or have no overpressure valve !
Nippondenso: 115 010-0431
Purflux: LS 186 Porsche , LS 412 , LS 582
Purolator: L 37031 , L 37231 , PC 202 , PC 214 , PC 231
SF-FILTER: SP 4320
Technocar: R 65
U.F.I.: 23.102.00 , 23.102.02 , 23.164.00 , 23.241.00
WIX (USA) : 51261 , 51609 , 51768
Woodgate: WGL 654
Airfilter
SDP Nr 712.1.19.002.1
AC: PC 180
Air Refiner: ARM 1344
Bosch: 1 457 429 932 , 1 987 430 016 , 9 541 160 016
Champ: AR 148
Coopers AZA 633
Crosland: 9530
Donaldson: P 14-0131
Digoema: DGM 01106
Fiaam: FLI 6458
Finnfilter: FFA 892
Fleetguard AF 4067
Fram: CA 3105
Hengst: E 122 L
Hirschi SA 14017
Knecht/Mahle: LX 200, AG 73
Kolbenschmidt 034-AR
Luberfiner: LAF-1710
Mann-Filter: C 13 114/4
Purflux: A 796
Purolator: A 57096 , PM 1096
Savara: SA 412 , 9.23.412 , 9.32.782
SF-Filter SL 6208
Technocar: A560
TEHO: 1-28
U.F.I.: 27.881.00
WIX (USA) : 46415
Woodgate: WGA 106
Fuelfilter
SDP NR 712.2.08.107.0
AC: FS4 , GF 142 , GF 501 , GF 61 , GF 65 , GF 94
ADL: ADH 22303
Bosch: 0 450 904 004 , 0 450 904 061
Champ FN 18
Crosland 6681 , 700K , 701K , 702 , 702K
Fiaam: FT 5170 , FT 5223
Fleetguard: FF 5015 , FF 5016 , FF 5060
Fram: CR 121 , G1 , G12 , G2 , G2A
Hengst: H100WK
Kayser: AK 01-6/8U
Knecht/Mahle: KL 11 , KL 12
Kolbenschmidt: 068-FP , 274-FP
Laurette: ELE 3576
Luberfiner: G 5/16
Mann: WK 42/1 , WK 43/1 , WK 818
PBR: BF 1001
Purflux: EP12
Purolator: F20011 , F57018 , F68143
U.F.I.: 31.010.00
VIC: FC-405
Grettings from Germany
Oilfilter
ADL: ADI 32101
SF-FILTER: SP 4320
Technocar: R 65
Woodgate: WGL 654
Airfilter
AC: PC 180
Champ: AR 148
Coopers AZA 633
Crosland: 9530
Digoema: DGM 01106
Fiaam: FLI 6458
Finnfilter: FFA 892
Fleetguard AF 4067
Fram: CA 3105
Hengst: E 122 L
Hirschi SA 14017
Purflux: A 796
SF-Filter SL 6208
Technocar: A560
TEHO: 1-28
U.F.I.: 27.881.00
WIX (USA) : 46415
Woodgate: WGA 106
Fuelfilter
ADL: ADH 22303
Champ FN 18
Hengst: H100WK
Kayser: AK 01-6/8U
Laurette: ELE 3576
Luberfiner: G 5/16
PBR: BF 1001
Purflux: EP12
U.F.I.: 31.010.00
VIC: FC-405
