O.D./Infra Red paint
Kiwibru
Post by Kiwibru »
Is there a specific formula or paint number for the standard O.D. paint used on the Pinz? Sources or other tid-bits appreciated.
Wayne Roberts
Post by Wayne Roberts »
Sean at EuroTruck had some a while back. I dont know if is still available. Most paint shops can do a good eye match and get close but it will not have the IR capabilities, if that is what you are looking for.
2012
Post by 2012 »
ir paint is available for houses and other things. i'd expect you can pick your color just like all other paint.
Twin Pinzies
Post by Twin Pinzies »
What about the stock military OD paint also being chemical/biological attack resistant? I learned that it was.
Kiwibru
Post by Kiwibru »
Not really needing the Infra Red capabilities, just the color match.
I guess I will take some removable item from the truck to my friend who does paint at the local hardware store and see what he can come up with. Got some areas I want to treat with POR-15, then paint over. Thanks for the replys.
1975 710M
MarkPinz
Post by MarkPinz »
Here's a link to a place that sell several military colors mostly US stuff thou: http://www.avettruck.com/Featured_Produ ... e_pai.html
Just get in and go....
ms1223
Post by ms1223 »
Check out Rapco parts. They have the CARC style paint you are looking for. I have had good luck with all the paint I have purchased. They will let you mix colors for a full case price.
http://www.rapcoparts.com/sigaofpa.html
Swifty 72 710M
MarkPinz
Post by MarkPinz »
That place is a heck of a deal, we pay as much as $300.00 /QT for some automotive colors at work :shock:
Dean
Post by Dean »
Could some one explain the purpose and function of the Infra Red capabilities of the paint. Is it to adsorb the infrared or reflect it?
2012
Post by 2012 »
absorbing ir is easy. if you paint it black you've got your oven (easy to see with ir cameras). that's what the rolling stones were talking about, pretty sure. or maybe not. 8)
Kiwibru
Post by Kiwibru »
Thanks for the Rapco link, that is really great!
1975 710M
Scooter
Post by Scooter »
Is this the right paint "34094 383 Green (CARC) Substitute" to match the orginal Pinz color?
I am doing some touch up and can not seem to find a good match.
Scooter
tokarev
Post by tokarev »
383 CARC is not a match for the pinz
Home of the SHTF50 and SHF/R50 .50 BMG Rifles
kc4mne
Post by kc4mne »
The Pinz Color is RAL 6014 (Yellow Olive)
You can go to a sherwin williams chemical coatings paint store and have them mix it in quick dry enamel in a satin finish.
Of course paint fades so don't expect an exact match to existing color
Kiwibru
Post by Kiwibru »
[quote="kc4mne"]The Pinz Color is RAL 6014 (Yellow Olive)
OK, but the folks at my local S.W. store looked at me kind of funny when I asked about "RAL 6014". Turns out the RAL is a European color standard.
The S.W. folks said they could match a color (give 'em an appropriate part with said color) but as for actual color number that is unknown. They also said the automotive division would be able to produce a much more "robust" exterior paint for re-painting exterior surfaces.
So, another trip with a sample may finally give some formula for RAL 6014, Yellow Olive (Flat O.D.)...
1975 710M
Locked
