Starter button
Starter button
When I push the starter button on my truck it starts right up and runs fine as long as I hold down the button. As soon as I let off the button the truck dies. I took apart the switch and cleaned it up but it still does it. Any suggestions?
Greg
Greg
1973 710M (sold)
1976 712M (sold)
Looking for a Haffy
1976 712M (sold)
Looking for a Haffy
ballast-resistor
Also check the connections of the ballast-resistor(that round thingy under the dash that normally gets quite warm) as well as the resistor itself. Infact in normal operation, starter button released, the voltage drops from 24V down to approx 18 V by passing trough this resistor. Hope this helps.
Sorry I haven't had time to check this board for a while so you probably have this all figured out but John is correct that you get extra voltage while the starter button is pressed.
The way this works is that there are three connections on the starter button so when you press it in you get 24vdc on two output connections. One goes to the starter selonoid and the other goes back to the starter swich through a secondary set of internal switch contacts, then connects down to the ingnition wire past the balast resistor. so your problem could be a bad ignition switch, the balast resistor or the molex type connector that the balast risistor uses to connect with.
Rich A.
Rich A.
Well I replaced the ignition switch(ouch) to no avail. so I called Dennis and they suggested it might be the rev-limiter. And through the process of elimination we isolated it down to that. The cure for me was to jump the incoming and outgoing lead together as per Linden's advice and it works perfectly. Eventually I'll probably replace the part or maybe not.
Thanks for all your help.
Greg
Greg
1973 710M (sold)
1976 712M (sold)
Looking for a Haffy
1976 712M (sold)
Looking for a Haffy
Greg
Well done, nice to hear when something goes right. That rev limiter unit by the way is a pricey unit. If you intend to run the truck for an extended period sans "box" remember that you can over rev the engine in mountain conditions leading to some expensive failures.
Best of luck and I will drop you a line when I am next in Sparks at the Willis Works.
Dennis
Dennis
OOOps no customer bashing now
