Fuel Delivery Problem-Why cant we use 5/16 fuel line?
Okay-short version: Thought my fuel pump went out again. Put electric on it to see if it would work. Nada! If I pressurized the tank, it would kick on. Thought tank was clogged and had it boiled out. Hooked it all back up and still same thing. I replaced some of the hose with 5/16 and still nothing. ANY IDEA WHATS UP!!! Im goin crazy here. Should be something simple. As long as I pressurize the tank it gets fuel-after that it stops sucking. What the crap could this be? Can I replace all the fuel line with 5/16--something tells me its not the problem either.
Watch out for the braided hose,it can look great,but will still "weep" while running and bleed when stopped.
Follow the lines all the way back to the tank and replace if it is the old stuff,also look for kinks. With Jim's thought,it should stay running if you leave the cap off...
I guess big ?? here is does it run and die after a drive,or does it not want to start after sitting overnight,week,month?
Mark
Mark
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
68 Haffy
