24 to 12 volt converter instal Question
andy
Post by andy »
BTW, what are the outlets for or is that where you bring in outside power?
A bar F
The buck STARTS here
www.deerleaseservices.com
goudacheese
Post by goudacheese »
The Alternator is Stock and I am only using the 2 Optima batteries. I have not changed anything mechanically (I am am more electrically inclined (I am an X Electronics Engineer) then mechanically inclined). I did add a K&N Air Filter, the REGULATOR HOT AIR W/ THERMOSTAT from SAV, http://www.swissarmyvehicles.com/showde ... 121195019/
and a magnetic fuel automizer
I noticed immediate power with the K&N Filter. I installed the fuel automizer and the Hot Air Regulator at the same time and now the truck really takes off , so I don't know if it is the fuel automizer or the regulator or maybe both. Oh, I also added a battery nano pulser http://sports-imports.stores.yahoo.net/12vonabaco.html
The AC & DC outlets are for outside power.
By the way I am also using a 24 volt 30 amp heater and it hasn't caught fire yet, nor do I expect it to! I actually had all the lights on and the heater (with the engine running) without any problems. I tapped into the power that was feeding the gas heater. I was waiting to smell smoke and I was feeling all the power wires to see if they were getting hot, but nothing (I was actually disappointed and happy at the same time). I like to use 10-12 gauge wires for everything. I buy all my electrical stuff from http://www.delcity.net/.
Your only limitation, is the creativity of your imagination!
todds112
Post by todds112 »
I am really interested in these. Has anyone just installed this over the stock older set-up and did it make a notable difference?
1973 712M
NM_Mogman
24 to 12V Converter install
Post by NM_Mogman »
Hello all,
I have just bought a 24v to 12v converter to install in my 710M and have never done it before. I have three wires, red (power), black (ground) and white ("connect to the LOAD(s)"). Can someone draw me a little schematic showing how this will be done as I am electronically challenged;-) I want to add a fuse block for the accessories also but have more want than knowledge. Thanks,
Phil
'75 710M
Rio Rancho, NM
Post by Jim LaGuardia »
That K&N filter will shorten the life of your top end :shock: It allows larger particles to pass through, not good for sand or dusty trails.
Cheers, Jim LaGuardia
"Arch Magus of Machines."
75pinz
Todd
Post by 75pinz »
I had one of those on my 3rd to last 6x6. I noticed no difference in how it ran v. the older setup. It didn't warm up any faster or anything that I could tell.
Brickren
Post by Brickren »
Wasn't there a post about a dyno test that proved a k&n actually robbed some power from engine? Thanks for the top end info, Jim. Brian
1975 710M
2000 Ural Tourist
M Wehrman
Post by M Wehrman »
Jim's right, Dodge used to void your powertrain warrantee if a K&N was present and you had a motor prob. Due to the excessive dirt ingested. :x
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
Locked
