Block heaters - yup might sound like a stupid question
But I have only owned one vehicle that never needed it and that was my bike. I know these are air cooled but I had to ask the question cause our stuff is hard to start up here when she gets real cold.
Sorry about my ignorance
Jer Bear
Jer Bear
- Jimm391730
Depends on what you mean by "real cold", our 710M with properly adjusted, well functioning carbs and pertronix and civi ignition fires right up down into the teens (well, it has to crank 5-10 times to fill the carb bowls, but once they have fuel it starts right up with full choke). How cold do you usually get?
712W w/FI and 710M
712W w/FI and 710M
cold
it's not as cold here as in the Yukon. However, I have seen 25 below with several Pinzgauers with absolutely nothing besides decent batteries and thin oil. I use 5 w30 in the winter here in Iowa. My guess is it will start better with a battery warmer but they do very well otherwise.
Yeah, it's gettin the darn engines to stay warm after they have started that is the challenge. Air cooled is just too efficient in the cold nordic air. I used to have a VW bus in which I dedicated one of the heater outlets to the air intake (via the air filter) so as to prevent roadway carb freeze ups in the lower teens and minus ranges. Guess that's why that Pinz air cleaner heat flap is such an important detail these cold months. But still, I have admit the Pinz is a bugger to keep warm or warm in! Guess you will have to see what your experience is and re-plan accordingly.
Happy New year!
Happy New year!
1975 710M
Jerbear- seems to me i recall people using dipstick heaters and battery blanket heaters on their vw bugs in Goose Bay , Labrador when growing up( 40 years ago) -40 not uncommon there. i recall few years ago driving thru Yukon in mid dec. that two days it was -44F and i did not have block heater in the new car we were driving up.
i would also think something to restrict air flow may be helpful when driving and it is so cold.....not sure if there would be downside to that, Dennis might have an idea,
the guy that i got my pinz from used synthetic oil so i have continued that as i recall there was significant discussion here somewhere about synthetic oil use. pros and cons.
mine is sluggish to start but i think that is due to battery strength. barely turns over @ zero but will eventually start.
And then Pinz doesn't have a thermostat like a VW or Porsche to help it warm up.. THe oil T stat does NOTHING for cold heads..Yeah, it's gettin the darn engines to stay warm after they have started that is the challenge. Air cooled is just too efficient in the cold nordic air.
Makes zero sense to me..
Guys
I have seen Pinz folk blank up the air intake here in Colorado on very cold days to improve engine temperatures.
The problem is that Colorado also has sudden warm days in winter; so owners also forget that the engine is blanked up, hence no cooling. That can and WILL cause some expensive repairs to the top end if you are neglectful.
As for block heaters I suppose you could use the mentioned pan heater but syn oils would obviously help when its 40 below.
You could do what the Turkish truckers did about 30 years ago before the advent of plastic air and fuel pipes. In short light a tyre on fire a bung it under the truck. That keeps things toasty warm all night! NOT recommended!
Dennis
Dennis
OOOps no customer bashing now
electric heat
here is a wonderful place to get heat strips tape probes and any kind of controller you need we use this site for a lot of projects
http://www.omega.com/heaters/hsc.html
... heated seats would be a nice addition also ...
It is only air and fuel ...For every 1 lb boost will gain you 10 % displacement
Block heaters
Drifting a little off subject.... I have been concerned about the oil temp and cold wx also. My issue is not so much starting but while running, my oil temp was averaging about 125 - 140 Degrees F., not really warm enough to cook the moisture out of it.
I installed insulation made of foil and foam sandwich, 1/4 inch thick and covered the lower part of the engine (sump), covering the bottom and the sides as high as I could easily go. I cut a piece of foam centering it up on the oil pan and cut 4 notches so I could fold the sides up, used aluminum foil tape to seal the fold seams and then used a LARGE cable tie, wrapping it around the foil blanket about 3 inches above the pan bottom to secure it.
Now my engine in 25-30 degree F. wx, runs about 160 degrees F. I would really like it to run about 180, but this is a start.
Tom E.
712 M
Sonora, CA
Tom E.
712 M
Sonora, CA
