TurboJim
Posts: 45 Joined: Mon Apr 02, 2007 6:17 pm
Post
by TurboJim » Fri Mar 07, 2008 2:13 pm
I want to lift my pinz 712 on a lift is there any lift points recomended for a regular shop lift
It is only air and fuel ...For every 1 lb boost will gain you 10 % displacement
MarkPinz
Posts: 115 Joined: Thu Oct 28, 2004 11:21 am
Post
by MarkPinz » Sat Mar 08, 2008 11:58 am
In an earlier post before the site crash, believe it was recommended to lift a 710 under the body mounts? Can't remember about the 712 thou?
Just get in and go....
TurboJim
Post
by TurboJim » Sun Mar 09, 2008 8:28 am
MarkPinz wrote: In an earlier post before the site crash, believe it was recommended to lift a 710 under the body mounts? Can't remember about the 712 thou?
i do remember that but i could not find it Thanks
M Wehrman
Posts: 847 Joined: Thu Apr 15, 2004 9:46 pm
Post
by M Wehrman » Mon Mar 10, 2008 10:35 am
I have lifted several Pinzes using the lip under the rub rail. Obviously one needs to have an above ground lift....
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
Scooter
Posts: 164 Joined: Sat Aug 21, 2004 5:32 pm
Post
by Scooter » Wed Apr 23, 2008 10:24 pm
I want to put my 710m on jack stands so I can rotate the tires. Are the lifting points under the body mounts the best place to do this? I looked at supporting it under the axle, but there is not enough room for the bottle jack and a jack stand. Here are the body mounts below.
I plan on doing one side at a time.
Front
rear
Any others ?
Scooter
MarkPinz
Post
by MarkPinz » Thu Apr 24, 2008 10:02 pm
That's the spot
Your undercarriage looks allot newer/cleaner than mine
Scooter
Post
by Scooter » Thu Apr 24, 2008 10:16 pm
Thanks, I had in under coated not long ago. Since we have not been able to drive our trucks here in Wis, it has stayed clean.
Well at least I can rotate the tires, even if I can not drive it yet.
Scooter
Erik712m
Posts: 1553 Joined: Sun Jan 21, 2007 7:52 pm
Post
by Erik712m » Thu Apr 24, 2008 10:22 pm
very nice scooter
