Hello Jim,
I'm glad your install is working well.
Jimm391730 wrote: and it was 18F. Truck started almost instantly, I set the idle and immediately got out to clear snow and ice. It idled perfectly. This is without any addtional cold start tweaking, just the setup that Jim L. gave me.
This is great, from your earlier posts it sounds like you are seeing a significant behavior change in cold torque, etc.
Not sure I understand the "set the idle" comment, tuning via laptop? or physically setting the idle. The idle air valve should handle that for you automatically.
The pinz is a bit cold-blooded, so we manage air (and thus idle) and as well as the traditional fuel warmup settings using almost ten different tables different tables to get the crank and drive away performance our market demands. All in the first 90 seconds of the engine running. This may not be as important to some, it is important to our market.
So if you saw large benefit from moving to sequential my strong suspicion is that you just leveled out air/fuel flow. Long way around to do that, and you really need to level out airflow first in your plenum design.
Probably mostly true, I knew from looking at the manifold that it was really only going to work properly with sequential ignition because of it's design. However, it appeared to be designed well for this mode and is (IMHO) extremely well built.
I've never said Jim's system was not well built. Or really anything about his parts. When negative comments are made about our system & design choices, I try to respond with what I know about the alternative design choices, etc.
Most of the time I can produce engineering & mfg data supporting that. (IE: O2 sensor location, Fuel delivery rates at different psi, etc)
I'm not the one saying the only way to realize pinz potential is with sequential fuel injection.
I can state as fact that the people who would buy our system if released would absolutely not buy your components.
FACT? This is just your opinion. Please keep facts seperate from conjecture. If this is how you define "facts", I am less impressed by your statements in general.
Well this is a fact. The people (and market) who are requesting our system have consistently balked at the idea of partial kits. And most feel they do not have the expertise to fine tune, or do the level of fabrication needed for alternative kits.
We see a fairly clean split:
A) those who want to piece a system together themselves, and are willing to do their own tuning, fabrication. Some, but not all of these want to be able to fiddle with settings.
and
B) those who just want a system that can be installed turnkey by someone with handtools. Any reasonable vw mechanic with enough expertise to swap an intake can install our system.
Jim's system clearly cater's to group A. It's available for the purchase, apparently works well. Certainly inexpensive enough.
Yet we still have people wanting to buy our system. Some have seen it, others just like what they have heard. In any case, there is a market for group B. They have not bought Jim's, or even Jake's system. for some very specific reasons. It's a different market & user expectation.
In conclusion, the EMS system works very well as full sequential with Beck's manifold. Until others get Jake's system installed and reviewed we won't have much of a comparison, will we?
Well, we should have two EFI'd pinzes at Steel soldiers. Anyone wanting to drive mine is welcome to. Herbert's is for sale, so anyone serious about purchasing it can talk to him.
I never said Jim's did not work or even ran well. It's Jim saying:
you will never know just how good a Pinz can run.
Or the implication that "now that they have blazed the EFI trail, others will follow".
I about choked on my coffee when I read that. There were multiple injected pinzes & haffies on the road before Goatwerks or Jake ever started.
Given Goatwerks has not seen or even has current details on our system, that's a a pretty bold statement. (Note the "you will never know") So there is no way to realize full potential out of a pinz without sequential? Just because Jim's unique arrangement responded well to sequential does not mean that all systems would respond similarly, or even need sequential.
We know we have even airflow in our intake/injector design. It's a tried & true plenum/intake/injector configuration invented by Bosch, and utilized in millions of production vehicles. accordingly, we have not needed per cylinder trim.
Again, I'm happy your install is working well. And we all benifit from having multiple solutions available.
I don't understand the rock throwing from Goatwerks, nor the repeated attempt to associate our system with that of the Red Bull trucks, etc. There are many design choices you can make. All have pro's & con's, often times offsetting. We've made some different design choices, for what we feel are good reasons. Jake even went a slightly different direction. There is room for all the alternatives.
Have fun,
Alan
