I am planning a long trip in the pinz and would like to use an aux 12v gel battery, not connected to the system, to operate a 12v cooler. I also have a small solar panel I would like to use. Is there a device to put between the solar panel and the battery to recharge it?
I am not an electrical wizzard but I imagine the battery hooked directly to a solar panel will not just recharge the battery but drain the battery. Looking for something simple and not too expensive. Ideas anyone?
Morris, 73 710M
Battery charger
Morris,
Check out my article on solar power for the Pinz here:
http://www.sdp-pinzgauer.org/html/solar ... the_k.html
Jay
W3PNZ
710K Kommandowagen
W3PNZ
710K Kommandowagen
Battery charger
Jay,
That does look like the answer. Where can I obtain a charge controller like the one you have installed? I think my solar panel is only 20 watts, it is not enough to operate the cooler by itself but should recharge the battery.
I have a 24 to 12 converter for the radio and CB but I wanted some power at night for the cooler when the pinz is off. I had trouble with the memory on the radio, too. I got a marine analog radio that seems to work ok.
Thanks for the tip.
Morris
Thanks for the tip.
Morris
Morris,
I bought the Morningstar charge controller on eBay for about 50 bucks. There are also many places on the Internet that have them too, for example:
http://store.solar-electric.com/ss-20l.html
I chose the model that has the LVD (low voltage disconnect) to avoid damage to the battery, although that might not be necessary if you use a deep cycle battery.
Jay
W3PNZ
710K Kommandowagen
W3PNZ
710K Kommandowagen
Hi Morris,
I suspect that you will need more than a "small" solar panel. Most of those coolers draw about 3 amps so you will need much more than 3 amps from the panel since the sun doesn't shine 24 hours a day. A better option would be to use a battery equalizer as a charger from the 24V system to the 12V battery. That is what I have been doing for many years. I also disconnect the equalizer and 12V battery from the 24V system with a couple of relays when the ignition is off.
Ron Schroeder
WD8CDH
'73 710M
WD8CDH
'73 710M
