E-Track Seat Belt Installation
Posted: Sat Jun 10, 2006 11:03 am
by hkmp5
I finally got around to putting seat belts in the back of the Pinz and after talking to Scott at E.I. decided to go with the E-Track solution. He sells the belts already made up with the correct end fittings so all that was needed was to buy the track locally and install. The track ran $16 each and I decided to mount them low enough that the bottom line of bolts went into the square tube that the side rails mount to. I used ten bolts equally spaced on the bottom and four bolts on the top, one through each vertical side wall support. It was super easy to do and solid as a rock! Here are a couple photos for reference.
http://pg.photos.yahoo.com/ph/hkg3sg1@s ... pg&.src=ph
