Oil Filter cross number for the U.S.
tokarev
Post by tokarev »
Been trying to pull up the site with all the cross reference part numbers but it wont load for me - need a cross reference part # for the pinz oil filter - I assume the Fram # on the filter is a good one here in the States.
Home of the SHTF50 and SHF/R50 .50 BMG Rifles
Wayne Roberts
Filter cross ref.
Post by Wayne Roberts »
I have never found a Fram that fits in stock anywhere. I always use the Napa 1768. The local store keeps one in stock for me. Here is a link to a filter cross reference.
http://www.rmpinzgauers.org/pinzgauerstuff.htm
Did your distributer ever dry out? I have run a small bead of silicone around the sealing area of the cap and have not had a problem with water since. Glad you made it this weekend.
MarkPinz
Post by MarkPinz »
Fram 36A Fram PH2842, If you haven't already checked it out here's a link to the Yahoo group http://groups.yahoo.com/group/pinzgauer/ there is loads of info.
Just get in and go....
tokarev
wet dist cap
Post by tokarev »
Wayne,
Had a good time - to bad its so dry in the green swamp. Once I found the wet cap and sprayed some WD40 in there all is well. I still have to get a long plug socket to tighten the one plug that was loose. I will try the Napa # here and see what they have. Looking under the truck yesterday I found a oil leak running down the right rear tire. Gear oil from the smell - so thats another thing I have to do.
Walter
tokarev
Filter #'s
Post by tokarev »
Mark Pinz,
Thanks for the info - off to the store.
Walter Keller
tokarev
filters
Post by tokarev »
Well I went to NAPA with the numbers (Napa #'s) from the yahoo site and they had all both filters in stock. Kinda pricey but I guess that goes with having the pinz.
MarkPinz
Post by MarkPinz »
tokarev, just noticed you're located near Tampa. My cousin lives nearby & tells me about the Pinzgauers around town, he really would like to have one. We get back there around October everyyear & stay with family in Sarasota.
Heres a few filter numbers
Oil Filter
NAPA 1283 or 1768 ,1768 HAS MORE CAPACITY
FRAM PH2842,PH6923,36A
A/C DELCO PF2044
BOSCH 72116
BALDWIN BT292
HASTINGS LF-404
RYCO 272
CAR QUEST 85768
DONALDSON P552819
PUROLATOR L30260
MAHLE OC54
WIX 51768
MANN W 940/29
tokarev
filter numbers
Post by tokarev »
Jim,
Thanks for the numbers - more options is always good. Went with the larger Napa oil filter.
Walter Keller
hkmp5
MANN Filter Qriginal Equipment Oil Filter
Post by hkmp5 »
The original equipment MANN Filter is actually the W940/5. The W940/29 that Jim listed is actually a Porshe filter but will mount and work on the Pinz. The OE filter has the wrench attachment on the end to ease service in the field.
Mit freundlichen Grüßen / Kind regards,
- Stu Miller
Manager, Design & Development
MANN+HUMMEL USA
phone: 269-329-3944
email: Stuart.Miller@mann-hummel.com
The true Pinzgauer´s
Post by The true Pinzgauer´s »
Hello Guy´s
here are my cross referent list for Petrol Pinzgauer´s. Like the TD list´s i can´t get any warrenty if the filters fit´s. Filters from Mann ,Fleetguard and Knecht are tested and they fitts.Also this list is made of cross-refernt lists from SF-Filter,Hengst,Knecht and Mann.
Oilfilter
SDP Nr 710.1.07.033.2
AC: PF14 , PF 32 , X2 , X21 , X29 , X47
ADL: ADI 32101
Bosch: 0 451 104 003 , 0 451 106 065 , 0 451 203 061 , 9 457 280 530
Coopers AZL 055 , Z66
Crosland: 640 , 319 , 660
Digoema: DGM/0 940/5
Donaldson: P52-8220 , P55-3411 , P77-9149 , P55-2297 , P55-2819 , P55- 5680 , P55-9418
Fiaam: FT 4790 , FT 4653
Fleetguard: LF 3402 , LF 654
Fram: PH 1 ,PH12 , PH 2802 , PH 2827 , PH 2815 , PH 2840 , PH 2858 ,
PH 2881, PH 2996 , PH 3569
Hengst: H17W01 , H170/1W
Knecht: AW 5-2 , AW42 , AW 512
Knecht/Mahle: OC 59 , OC 61
Kolbenschmidt: 154 05
Luberfiner: LFP 2538
Mann-Filter: W 940 /5 all other / (x) don´t Fit or have other overpressure
times or have no overpressure valve !
Nippondenso: 115 010-0431
Purflux: LS 186 Porsche , LS 412 , LS 582
Purolator: L 37031 , L 37231 , PC 202 , PC 214 , PC 231
SF-FILTER: SP 4320
Technocar: R 65
U.F.I.: 23.102.00 , 23.102.02 , 23.164.00 , 23.241.00
WIX (USA) : 51261 , 51609 , 51768
Woodgate: WGL 654
Airfilter
SDP Nr 712.1.19.002.1
AC: PC 180
Air Refiner: ARM 1344
Bosch: 1 457 429 932 , 1 987 430 016 , 9 541 160 016
Champ: AR 148
Coopers AZA 633
Crosland: 9530
Donaldson: P 14-0131
Digoema: DGM 01106
Fiaam: FLI 6458
Finnfilter: FFA 892
Fleetguard AF 4067
Fram: CA 3105
Hengst: E 122 L
Hirschi SA 14017
Knecht/Mahle: LX 200, AG 73
Kolbenschmidt 034-AR
Luberfiner: LAF-1710
Mann-Filter: C 13 114/4
Purflux: A 796
Purolator: A 57096 , PM 1096
Savara: SA 412 , 9.23.412 , 9.32.782
SF-Filter SL 6208
Technocar: A560
TEHO: 1-28
U.F.I.: 27.881.00
WIX (USA) : 46415
Woodgate: WGA 106
Fuelfilter
SDP NR 712.2.08.107.0
AC: FS4 , GF 142 , GF 501 , GF 61 , GF 65 , GF 94
ADL: ADH 22303
Bosch: 0 450 904 004 , 0 450 904 061
Champ FN 18
Crosland 6681 , 700K , 701K , 702 , 702K
Fiaam: FT 5170 , FT 5223
Fleetguard: FF 5015 , FF 5016 , FF 5060
Fram: CR 121 , G1 , G12 , G2 , G2A
Hengst: H100WK
Kayser: AK 01-6/8U
Knecht/Mahle: KL 11 , KL 12
Kolbenschmidt: 068-FP , 274-FP
Laurette: ELE 3576
Luberfiner: G 5/16
Mann: WK 42/1 , WK 43/1 , WK 818
PBR: BF 1001
Purflux: EP12
Purolator: F20011 , F57018 , F68143
U.F.I.: 31.010.00
VIC: FC-405
Grettings from Germany
