Swingfire Turbo Heater Installation
Posted: Mon Oct 23, 2006 7:50 pm
Hello All,
I thought all you Pinz drivers who live in cold environments make find this interesting:
Since it is starting to get cold already here in Michigan I took some time this weekend to do an experiment.....I installed a Swingfire Turbo heater in the back of my 710M.
Here are some photos:
http://new.photos.yahoo.com/hkg3sg1@sbc ... 1302#page1
The GOOD points:
- Easy installation
- Self contained - requires only power to start.
- No permanent visual modification - I added threaded inserts and one
7/8" hole for the exhaust all are hidden when the rear seats are
installed.
- Great air flow - the flow rate is strong enough to circulate hot air
through the entire vehicle interior without any secondary fan or ducting.
- LOTS of heat! (40,000 btu)
The BAD points:
- Slightly loud on the inside. Outside exhaust is very quite.
- TOO MUCH HEAT!
I tested it last night in 45 degree F outside temps and had to turn it off after about 15 minutes of driving. I was so hot in the interior that I had to open the cold air vent and I still could of worn shorts and a T-shirt! I was concerned a little with CO output which turned out not to be a problem. The meter peaked at 12 ppm when running and maxed out at 32 ppm about 15 minutes after I parked it with the heater off and a warm engine in a closed garage.
I will leave it installed hoping for a REAL cold day with lots of snow to see how it performs then.
The GOOD points:
- Easy installation
installed.
The BAD points:
- TOO MUCH HEAT!
