FCC relaxed license requirements.
dougj
Post by dougj »
All,
most of you use CB to communicate on the trail, but once you experience 2M bliss with a "real" radio, you'll wish the cb on your worst enemy!
the FCC just relaxed the regulations on licenses, eleminating the morse requirement on licenses above tech class. you will still need to take a exam, but the test is easy.
http://hraunfoss.fcc.gov/edocs_public/a ... 9012A1.pdf
many thanks to Scott R for the heads up on this.
there has never been a better time to get a A-radio license than now!
Dougj KC0MKB.
Kiwibru
Post by Kiwibru »
GMRS is a good band too if you don't want more than 5 miles (you can boost that with a repeater though). I found it to be more than equal or better than CB. Not much traffic, good quality radios from Motorola, Pryme,Kenwood and built to MIL spec. I am not referring to FRS which is much lower in power.
GMRS does require a license but there is no test!
1975 710M
AK NIMROD
Post by AK NIMROD »
WHAT WOULD BE A GOOD SOURCE TO FIND OUT WHAT NEEDS TO BE STUDIED FOR TEST. ARE THERE STUDY GUIDES OUT THERE FOR THIS.
WHAT RADIO WOULD YOU RECCOMMEND LOOKING AT?
THANX FOR ANY INFO -PAT
mjnims
Post by mjnims »
go to QRZ.com they have practice test you can take on line. The book we have been using which has over 200 questions straight from the test itself is "now you're talking"
AK NIMROD
Post by AK NIMROD »
THANX FOR INFO I'LL GIVE IT A LOOK
