Starter button
Posted: Thu Feb 08, 2007 11:48 am
by chapel
When I push the starter button on my truck it starts right up and runs fine as long as I hold down the button. As soon as I let off the button the truck dies. I took apart the switch and cleaned it up but it still does it. Any suggestions?
Greg
Posted: Thu Feb 08, 2007 6:44 pm
by russ
I don't have schematics in front of me but I had thought when you hit the button to start the truck, higher voltage ran through the coil. When released it went back to normal.
Posted: Thu Feb 08, 2007 7:28 pm
by Lightningpinz
(I don't have schematics in front of me but I had thought when you hit the button to start the truck, higher voltage ran through the coil. When released it went back to normal.)
Therefore, check the ignition switch (the start button is probably supplying the only voltage to the coil)
ballast-resistor
Posted: Fri Feb 09, 2007 3:28 am
by scoutpinzer
Also check the connections of the ballast-resistor(that round thingy under the dash that normally gets quite warm) as well as the resistor itself. Infact in normal operation, starter button released, the voltage drops from 24V down to approx 18 V by passing trough this resistor. Hope this helps.
Posted: Tue Feb 13, 2007 1:14 pm
by rla001
Sorry I haven't had time to check this board for a while so you probably have this all figured out but John is correct that you get extra voltage while the starter button is pressed.
The way this works is that there are three connections on the starter button so when you press it in you get 24vdc on two output connections. One goes to the starter selonoid and the other goes back to the starter swich through a secondary set of internal switch contacts, then connects down to the ingnition wire past the balast resistor. so your problem could be a bad ignition switch, the balast resistor or the molex type connector that the balast risistor uses to connect with.
Rich A.
Posted: Tue Feb 13, 2007 11:22 pm
by chapel
Thanks for the input. I'll get on this this weekend and post a report.
greg
Posted: Mon Feb 26, 2007 10:37 pm
by chapel
Well I replaced the ignition switch(ouch) to no avail. so I called Dennis and they suggested it might be the rev-limiter. And through the process of elimination we isolated it down to that. The cure for me was to jump the incoming and outgoing lead together as per Linden's advice and it works perfectly. Eventually I'll probably replace the part or maybe not.
Thanks for all your help.
Greg
Posted: Tue Feb 27, 2007 7:36 am
by lindenengineering
Greg
Well done, nice to hear when something goes right. That rev limiter unit by the way is a pricey unit. If you intend to run the truck for an extended period sans "box" remember that you can over rev the engine in mountain conditions leading to some expensive failures.
Best of luck and I will drop you a line when I am next in Sparks at the Willis Works.
Dennis
Posted: Tue Feb 27, 2007 11:31 am
by chapel
I'll keep that in mind. And we'll see you soon.
Greg
Posted: Tue Feb 27, 2007 2:17 pm
by todds112
Any pics or description of what it looks like and where it is? WOuld this also be the unit that triggers the "4500" light in dash?
Posted: Tue Feb 27, 2007 3:03 pm
by Foz
Mine doesn't wokr [but I don't need it - have a tach, and no mountains in sight from J'ville FL]... should I remove it/wire around it?
If so how?
What wires to splice.. which to cap off?
TIA
Posted: Tue Feb 27, 2007 5:31 pm
Just unplug the box and make a jumper with 2 male spade terminals , jump the 2 center terminals.
Don't forget to resecure the harness.
I jumped mine for EFI use(I used this circuit for ignition relay).
Posted: Wed Feb 28, 2007 11:03 am
by jgeesen
Where it be?
Posted: Wed Feb 28, 2007 12:47 pm
It's the only black box with the 6 wire connector to the righ side of the balast resistor behind the dash mounted to the body.
Posted: Thu Mar 01, 2007 9:39 pm
by Foz
Thanks Jim
