Door tops
Posted: Thu Jun 21, 2007 5:36 pm
by andy
Took the tops off the doors today. No sweat all the screws came out easily, no rust, the little foam strip was intact. Very nice. Now I'm trying to put them back in place and one end will go in and seat while the other end gets hung up. Fix the hung up end and presto the other end won't seat. What gives any tips or tricks to do this apparently simple operation?
Thanks.
Andy
Posted: Thu Jun 21, 2007 6:49 pm
by todds112
I had the same issues with mine. I actually bent the rods by hand to get them aligned correctly. I also had issues with the door tops not sealing, so I bent the rods "in" a bit. Just trial and errored it until, they dropped right in and sealed.
Posted: Thu Jun 21, 2007 6:57 pm
by andy
Thanks, I was considering bending them but thought I'd ask first. Will be back to trial and error tomorrow then. Taking the tops off the doors sure improves airflow and visibility.
Andy
Posted: Fri Jun 22, 2007 12:17 am
by todds112
I laid mine on a flat surface, with the outside facing down. I used an angle guage on the legs and tried to match it to the other door that fit right. Then I just fiddled with the fore and aft adjustments till it went in right. I was trying to avoid heating them and destroying the paint and insulation.
Posted: Sun Jun 24, 2007 7:15 pm
by andy
Todd,
With a little rebar and a 4 lb mallet (used lightly) we got the tops on. They seated sealed and there is no more noise in the cab than there was before. Thanks.
Andy
Posted: Sun Jun 24, 2007 8:00 pm
by todds112
Andy wrote:Todd,
Andy
Awesome. I also did the handle conversion like on SDP-Pinz site, then got some 1/16" closed cell rubber insulation tape that is 1" wide and put it on the bottom side of the tops. Works great and I can just lift them out and go. I'll put the bolts back in when "topless" season ends.
Posted: Sun Jun 24, 2007 9:11 pm
by andy
I know I've read the conversion, but apparently it didn't sink in at the time. I need to reread that. My concern was the day I took the tops off, that night it was going to rain and I just have a carport. I'm happy with my "small victories". New flasher, new gas guage, and the voltage regulator. I just hope nothing bigger is forced on me until I get some more confidence in myself. But, like the song said, "I get by with a little help from my friends...."
Posted: Sat Jul 07, 2007 9:26 pm
by PittsPinz
Has anyone come up w/an easy design to fabricate a rain gutter/drip trough to attach under the canvas over the front doors?
I like to keep my windows open & whenever I slow down/stop or open the door in the rain, it all pours into the opening.
There should be an easy way to bend a "J" trough to put between the canvas & the support cross bar w/4 cut outs for the top latch strap pieces.
Posted: Sat Jul 07, 2007 10:02 pm
by andy
I think the Yahoo Pinz group has pictures of what someone did that looks pretty effective. It's either there or in the SDP-Pinz site. I checked the SDP site real quick and didn't see it there.
Whoever did it, made it pretty simply and thought it out pretty well.
Rain Gutters
Posted: Sun Jul 08, 2007 2:24 am
by Wayne Roberts
Here is the link for the pictures. You must be a member of the Yahoo group to see them.
http://ph.groups.yahoo.com/group/pinzga ... rowse/d13c And here is the post on how to do it.
http://groups.yahoo.com/group/pinzgauer/message/32636
Wayne
door tops
Posted: Wed Jul 25, 2007 10:35 pm
by TurboJim
i found that if i measure the window post span and set them all at the same they drop in easy i have tried this on several pinz i have the measurement at the shop maybe my brother will post on this he was going to when we figured it out im guessing 32.25 outsides but i will check and theyn will drop right in
Posted: Thu Jul 26, 2007 8:39 am
by TurboJim
ok Im sorry it was 32 5/8 outside to outside and make sure that the rear pole is at about a 90 degree and you should be good ...let me know if it works for you
Posted: Thu Jul 26, 2007 6:02 pm
by Profpinz
Huh...ohh you mean 829 mm
I actually had one of my UNI students say to me once..."Whats an inch ?"
