A taste of Pinzgauer reality
Posted: Mon Jun 30, 2008 9:57 pm
by IwanaPinz
Hey guys.
All the fun and excitement of getting new tires and painting the under carriage just came to a screeching halt. :shock:
I notice that one of my axle boots (yellow, in fact all of the boots are yellow.) has a hole in it and another has what look like dry rot cracks, while another seem to have fluid pooling inside at the bottom. So that would make three out of six that need attention.
So I guess I am going to have a full time axle boot replacement experience.
Questions:
1. I assume its better, although much harder to do, to replace them with full boots.
2. Are the boots designed to keep stuff out rather that keeping stuff in?
3. Can it be driven with this sort of damage?
4. How hard is it to replace the boots? (Is this a one person job or a two person job, special tools and or facilities?)
5. Besides the boots what else should I order?
Ok that is enough for now. Thanks in advance for your advice.
Brian
1973 712M
Posted: Mon Jun 30, 2008 10:18 pm
by Erik712m
Its not the end of the world remember its a thirty old truck. I once was worried about all the little leaks, and chased them around until they were all repaired. It wasn't until i had conversations with other pinz owners like dave d and jim. that it was put in perspective. number one is the best 2 the boots are just dust covers to keep out the major water and dust out 3 if the fluids are checked and full it sure can be driven. 5 full boots are a pain to replace thats why most repalce with the split style 5 how far do you want to take it and how deep is your pocket book. I can tell you from experience one thing will lead to another before long you've spent 10k
Posted: Mon Jun 30, 2008 10:34 pm
Rears take about 2-3 hrs per side and fronts take a little longer and require a spring compressor. Boots wear out, split boots last a few years if installed correctly and yes, they keep the dust out and the oil in. Split boots take about 25 min to 1 hr each to install :wink:
Posted: Tue Jul 01, 2008 6:18 am
by ScottishPinz
Posted: Tue Jul 01, 2008 8:50 am
by Twin Pinzies
I've seen Pinzies with shredded axle boots that had been driven like that for years! Not mine though! Slap some split boots on, no big deal.
Posted: Tue Jul 01, 2008 11:57 am
by Protoman333
youve probably had enough feedback on this but...
ive replaced mine with split boots. easy repair. a filthy dirty dirt in the eye kind of repair, but easy. the worst part is (dunh) just removing the old ones.
mine have lasted about 6 years or so now and are just now starting to show signs of weathering.
Posted: Tue Jul 01, 2008 3:56 pm
by Heed
There was some talk in earlier posts that there was a vast quality difference in some of the split boots (kinda like the Indian-made spark plugs, etc).
I was able to pick up a factory SDP split boot that I keep in my emergency repair kit, but I have never seen it indicated on the E.I. or S.A.V. sites where their boots are from.
Can anyone chime in with where their boots were manufactured?
Axle Boots
Posted: Tue Jul 01, 2008 5:55 pm
by SAM. C.
Hi All
Are there any step by step instructions on how to replace the yellow non-split boots anywhere? I have had a look around and cannot find any.
Sam
Posted: Tue Jul 01, 2008 8:16 pm
by eaweidner
I got a pair of split boots recently from SAV. I am not sure who makes them as they come in SAV packaging. They did however come with complete installation instructions. I replaced two boots 2 years ago and they have held up well. I was told that these boots were supplied by EI by the dealer I purchased the truck from. Also, for what it's worth, we experience pretty good weather extremes here in Iowa and I have been pleased with their performance.
Regards,
Eric
Posted: Tue Jul 01, 2008 8:29 pm
You will find the procedure in the service manual under wheel drive removal/replacement.
Once you remove the wheel drive, replace the boot and re assemble 8)
You will need a spring compressor for the front springs. Do not compress the springs to less than 10.5 inches or you may damage them.
stay away from the ebay boots !
Posted: Tue Jul 01, 2008 8:51 pm
by man on the mule
i bought my pinz last summer and it had three of the original yellow boots split. i got the cheep boots off of ebay and they took about three months to turn into ribbons . i guess its the material , but they seem to have instantly dry rotted. the one that i kept in a plastic bag still looks new and soft (i bought four) the others that are onthe truck can easily be torn with two fingers. now for my question..... the seal that is behind the boot that is actually supposed to seal the oil in ,is it the pain in the but to fix? is it a pull the wheel ass. just like the one piece boot? i live 9 miles from the asphalt and the road is sandy to powder dirt. i need boots probably a little more than the average bear i guess.
Posted: Tue Jul 01, 2008 10:04 pm
by IwanaPinz
So the consensus is that the split boots are fine and as long as they are installed correctly they should last several years.
One post suggested that there are differences in manufactures.
From what I have read in the posts, that SAV is the best bet.
Thanks again everyone.
Brian
Posted: Tue Jul 01, 2008 10:45 pm
by andy
When I had the rear spring cups replaced last year by Robert Crow he put half boots on the rear axles of my Pinz. I've been worried to death after reading what's on this forum because a lot of the ranch roads have bushes and small trees growing in them. Plus I end up going down some bulldozer cuts made by the seismic crews sometimes and I am always worried the bushes and branches are going to shred the half boots, but (knock on wood) so far so good. I believe Robert got mine from SAV.
Andy
Posted: Thu Jul 03, 2008 10:32 pm
by ExpeditionImports
SAV and EIC use the same manufacturer of the split boots. I am familiar with 2 aftermarket Mfg's on these boots. There is a huge difference in the durometer hardness of the materials being used in both versions. We have been pleased with the more flexible versions and have supplied these for the past 3-4 years. I have not bothered to check on the Factories price for their split boot, I would assume it is beyond reasonable when a suitable more cost effective option is currently available.
Lots of talk in the past on the split boots. Our opinion is simple, if you are going to be in the drivetrain for other maintenance/repair procedures, then replace with a single piece boot. If the sole purpose is boot replacement, use a split boot until the time comes when you will be in the drivetrain.
Scott Ingham
